Re: What are the other grilles for the 81-81?
Next question, if you had to buy a good quality replacement for your oem grille, where would you get it from? The one I'm using from ebay has cracked just from the stress of being mounted correctly. Apparently it can't even flex what little amount it has to from all the fasteners being on.
Side question: Does anyone know if this paint scheme was typical? So the white roof, combined with the white side. I thought if you had a roof that was a different color than the hood, you didn't get the roof color running down the side. I thought it was only on the bottom. Did they make some trucks like this? Or is this one a custom job that deviates from factory? White roof and a white side. Instead of white roof, white bottom. https://external-content.duckduckgo....6pid%3DApi&f=1 |
| Bookmarks |
