Old 04-19-2022, 11:08 AM   #1
chev-obsession
chev-obsession's Avatar
Dull tail light lens
I have some tail light lenses that are in really nice condition, no cracks or oxidation etc and would like to polish them up so they shine.
What is the best way to do that? I can get som pictures later.
chev-obsession is offline   Reply With Quote
Old 04-19-2022, 11:45 AM   #2
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: Dull tail light lens
I used white polishing compound, but have switched to LED stop/tail lamps now.
~Steven
Simi Valley, CA
Old 04-19-2022, 08:18 PM   #3
72c20customcamper
72c20customcamper's Avatar
Novus polish with a small power ball . Or any kit for headlamps
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
72c20customcamper is online now   Reply With Quote
Old 04-20-2022, 08:32 AM   #4
sick472
sick472's Avatar
I have used Meguiar's PlastX Clear Plastic Cleaner & Polish with very nice results. It says it will remove fine scratches, but that is just marketing in my opinion. I am sure it does what it says, but the "fine" scratches that it removes are the ones that you cannot see with the naked eye. You cannot rub enough to remove a visible scratch, but the invisible scratches it removes along with any light oxidation really makes a difference in the shine. I do not use a power tool and ball or wheel...just my fingers and a piece of cotton T-shirt. It should take about 5 to 10 minutes of rubbing per lens, if that.
The lens' I did had some overspray on them too. With some extra time spent in those areas, the overspray was removed too.
He who is without oil shall throw the first rod. Compressions 8.7:1
1972 C10
1976 C10 (parts truck)
1985 K20
sick472 is offline   Reply With Quote
Old 04-20-2022, 05:20 PM   #5
FirstOwner69
FirstOwner69's Avatar
I have used the 2 Meguiar's products in tandem (cleaner first then polish) for years with great results.
https://www.amazon.com/Meguiars-10-P.../dp/B0002VAZ34
Jim
FirstOwner69 is offline   Reply With Quote
Old 04-20-2022, 07:35 PM   #6
cj847
cj847's Avatar
The only issue with this is that the compounds cost more than new lenses. So, unless you have some laying around........
cj847 is offline   Reply With Quote
Old 04-20-2022, 08:11 PM   #7
FirstOwner69
Correct, they are not cheap. However, I've been using the first bottles I purchased on numerous projects for at least 20 years. It goes a long way.
Jim
Old 04-21-2022, 10:03 AM   #8
sick472
sick472's Avatar
Same here. I'd say I have 1/3 bottle left and have polished 3 sets of plastic headlights, a set of large Pontiac tail lights, a set of C10 tail lights, and a few odds and ends.
Edit: a 10 oz bottle of the Meguiar's PlastX Clear Plastic Cleaner & Polish should not run more than $10. That's what I have.
1972 C10
1985 K20
Old 04-22-2022, 04:55 PM   #9
chev-obsession
Thank you for all of the responses! I ended up getting Meguiars plastix since they had it at the parts store. I will post pics of before and after. They had a slight film of road grime from never being washed in the last 50 years (the slip in camper covered them). I washed them with simple green and a soft bristle brush and they look really nice, hopefully the polish really makes them shine.
1965 c/10 swb
1969 c/10 lwb
