Blue 67
![]() Join Date: Apr 2004
Engine mounts: any tips?!
Hi:
I am replacing the engine in my 67. I have always had clamshell ones so, these ones are new to me. I had hard time even removing the engine since the center bolt getting cut to the engine mount perches' center holes. It seems if the engine doesn't come up %100 straight (or goes down straight), it would be impossible to remove/install the engine. So, here are the questions: - How do you install these mounts? - Does the center bolt gets bolt up after the engine is dropped in place? That would be hard to align to the hole on the perches! - Do you mount the engine mounts to the perches first and then drop the engine? - Can you just convert to clamshell ones? - Any other tips?
1953 GMC 3/4 ton: current project 1967 C20: 5.3 voretc with T5 conversion, 4 wheel 8 lug disc brake 1972 Nova: my 4 door sport sedan! 5.3 voretc + T5 conversion. drivable project, FUN!! 1979 Camaro Z28: 5.3 vortec conversion with build TH350: drivable project, Fun to drive 1992 Camaro RS convertible (Z28 clone): 5.3 conversion with build T5: on going project 2005 Silverado 2500, 4x4 Duramax, original owner |
![]() ![]() Join Date: Jan 2005
Re: Engine mounts: any tips?!
If you loosen the bolts that attach the engine stands to the frame and cross member, then you can move the engine stands around to align them with the center bolt on each motor mount. This is the only way I've been able to get those bolts to line up.
#3 | |
I'll come back later with part numbers.. EDIT to post additional information Here ya go.. https://www.performanceonline.com/19...engine-mounts/ They're cheaper at Summit, plus free shipping. |
It also pays to have a good mechanics mirror to do this job. Position it to see if you are lining up. I still have trouble when I just have a bare frame. Paitience and perseverance.
:My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=807535 1972 K10 swb/1968 Camaro 350/4spd 1955 210 2 dr sedan/1998 RCSB Z71 |
Blue 67
Boy!, seems like a painful process! Specially when you consider that the bellhousing bolts are also have to line up.
About the center bolt, I can't see (too much old oil leak and grime) through my current mounts, is it a bolt which has been introduced from the back of the mount (the engine block side) or is it just a threaded rod? Thanks for all the inputs.
![]() Join Date: Feb 2016
Here is a thread I posted some time ago show how to modify the drivers side mount for easier installation especially on power steering trucks.
http://67-72chevytrucks.com/vboard/s...d.php?t=773824 The only other thing is to loosen all the mounting bolts on the stands and when putting the bolts in the motor mounts don't tighten any of them until they are all started. It's kinda of a pain on most trucks but on some everything just lines up magically. Good luck.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
#7 | ||
Blue 67
You could try and use the 4X4 mounts. Instead of a stud sticking out they are threaded so you put a bolt up from underneath.
![]() Join Date: Dec 1999
Was going to suggest that myself. I have a pair of poly BB mounts that are the same as the 4x4 mounts I purchased from Brothers some time ago. I am not using them. LMK if interested and I will put them up in the parts section for you.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
Blue 67
Well, I decided to upgrade to the newer model engine mount. I place an order on POL for newer engine mount bracket but the next day I got notified they are on back order for 3-4 weeks! Since I wanted to get my LS swap finished in 2-3 weeks, I ended up building my own. More detail is in LSX section but here are few pictures:
![]() Join Date: Oct 2005
I used to work fleets of trucks that used these mounts. I always hogged out the hole in the bracket with a torch or step drill. The thick washer covered the hole.
George |
