Old 04-23-2022, 02:47 AM   #1
Accelo
Accelo's Avatar
Is this correct for the p/steering frame clamp?
I found this in a bunch of parts I have.
Is this correct bracket for the power steering lines frame clamp?
It doesn't seem correct to me as I thought the retaining bolt went in from the top?
If it fits I may use it, in this application, even if it's not technically correct.
After I wrote this I found it in the manual. Called a clip.
Guess it is not correct. Anyone know where I may have come from?
Accelo is offline   Reply With Quote
Old 04-23-2022, 04:51 AM   #2
kwmech
Re: Is this correct for the p/steering frame clamp?
AC maybe from the battery tray clamp
Old 04-23-2022, 07:24 AM   #3
mr.mud1
mr.mud1's Avatar
i will check my truck shortly when i go to the shop but it does look like the clip for the A/C lines under the battery tray.i know the bolt in my power steering lines does go down into a nut under the frame rail flange.i will check.
mr.mud1 is offline   Reply With Quote
Old 04-23-2022, 12:19 PM   #4
Accelo
Accelo's Avatar
I tried it on the air battery box and it fit perfectly.
Thanks you guys nailed it.
If anyone has the factory correct p/steering clamp I would be interested.
Summit sells one that is close. Made by "The right stuff".
It is $3.99
I would like to see them both side by side.
Is the retaining bolt threaded into the frame or is there a nut on the back side?
Old 04-23-2022, 01:26 PM   #5
Fbks_Cruiser
Fbks_Cruiser's Avatar
I just worked on mine yesterday. Nut on the bottom/back.
1972 GMC K2500 Super Custom
Matt
Fbks_Cruiser is offline   Reply With Quote
Old 04-23-2022, 03:39 PM   #6
Grumpy old man
Grumpy old man's Avatar
It is $3.99
The one from Summit works fine .
