Old 03-13-2022, 11:07 PM   #751
Kronald_70GMC
Kronald_70GMC's Avatar
Re: My 1970 GMC “Project Splice”
Originally Posted by Getter-Done View Post
That is a Super Cool Room
Thanks!
Kyle
1970 GMC "Project Splice"
2017 Yukon Denali (Daily Driver)
Kronald_70GMC is online now   Reply With Quote
Old 03-19-2022, 05:57 PM   #752
Kronald_70GMC
Now that I'm getting back into working a labour intensive job, the first couple weeks were hard. I was so exhausted by the time I got home that I basically ate and went right to bed. Now that I'm getting back into the swing of things, I finally had enough energy to hop back out in the shop and do some more sanding and another coat of filler today. If everything goes to plan I should be done with filler by next weekend. Then I can start getting ready to lay down some primer.
Kyle
Old 04-03-2022, 04:27 PM   #753
Kronald_70GMC
I need to stop setting deadlines for when I think primer will happen. I never hit it anyways! Of course I had to go and get sick somewhere last weekend so I haven't been able to get out and do anything until today. I'm down to the last detail in the driver's door jamb. Hopefully life will let me have a few more good days on it soon so that some real progress can happen.
Kyle
Old 04-05-2022, 09:24 AM   #754
sakustoms
I know the feeling. I set my sons cab aside to focus on finish welding the frame and trailing arms. All I needed to do was install a 220V outlet on the outer wall of my house so I could run an extension cord to the garage and plug in my new 220 welder. I bought everything and it still took me over 2 weeks to install the outlet. Feels like nothing has been getting done in a long time.
sakustoms is offline   Reply With Quote
Old 04-09-2022, 06:49 PM   #755
Kronald_70GMC
Well I finally have something for you guys to look at other than dust. It's not quite primer yet but I did get the last of the filler done today and did a decent cleanup in the shop. It's finally ready for primer prep!
Kyle
Old 04-09-2022, 09:00 PM   #756
chewychevy67
Lots of work to get to that point. Looks good.
chewychevy67 is offline   Reply With Quote
Old 04-09-2022, 09:49 PM   #757
Kronald_70GMC
Thanks! It feels good to get to this point.
Kyle
Old 04-16-2022, 07:41 PM   #758
Kronald_70GMC
Exclamation Re: My 1970 GMC “Project Splice”
Ladies and gentlemen, we officially have primer! So beyond stoked to finally be over that hump.
Kyle
Old 04-16-2022, 10:13 PM   #759
Scurry67
Right on man. That’s an awesome milestone. Keep at it.
67 SWB First Build
http://67-72chevytrucks.com/vboard/s...d.php?t=777171
Scurry67 is online now   Reply With Quote
Old 04-19-2022, 08:23 AM   #760
sakustoms
Looking good. How did you manage to spray in what looks to be your home garage?
Didn't you have primer everywhere including outside?
Old 04-19-2022, 08:37 AM   #761
Kronald_70GMC
Thank you!
Haha well being that primer is very thick and heavy, I find that if falls to the floor quick and dries before it gets there. I wouldn't do anything more than prime in there.
Kyle
Old 04-19-2022, 12:00 PM   #762
sakustoms
Originally Posted by Kronald_70GMC View Post
Thank you!
I'd be afraid to try that in my garage. I sprayed some high build from a can in the door jams on the c10 and that crap was on my Jeep outside in my driveway with only the man door open on the other side of the garage.
Old 04-21-2022, 12:29 AM   #763
Kronald_70GMC
Today I started fabricating a new cab mount nut as I somehow lost one of mine. I found the base piece on the left in my scrap metal bin. What are the chances of that happening? Luckily my dad had the correct size of square nut so all I really had to do was make the cage for the captive nut. I've got a few small things left to do on it and I can weld it all up and get them installed on the floor.
On a side note, I finally found the leak in my air system that has been driving me crazy for months. Unfortunately my secondary air tank that I painted up and hung on the wall has sprung a leak in the bottom. The previous owner must have left water in the tank for years and it rusted through so now I'm back down to 20 gallons of air until I can afford to replace it.
Kyle
Old 04-21-2022, 11:08 PM   #764
Kronald_70GMC
Well now that those are done and mostly out of the way (still need to be installed) I decided to start playing around with my seats, console and behind seat audio box. I put in my driver's side seat on some blocking to get to a height and pitch that I'm happy with. Near as I can tell with measurements off my dad's truck, I've settled on stock height at the back, down an inch in the front and slid back as close to the rear panel as possible. This gives me just a bit more headroom as well as legroom since I am 6'-2". Once I had that established, I started creating the skeleton of my behind seat box. It will follow the same slope as the seatback until it hits a level line from the tip of the rear floor hump, then it will drop vertically till it hits the floor. I think that will look best.
Kyle
Old 04-22-2022, 08:10 PM   #765
Kronald_70GMC
There we go, the skeleton is complete.
Kyle
Old 04-22-2022, 09:08 PM   #766
chewychevy67
Nice use of the gas tank mounting threads.
Old 04-22-2022, 09:47 PM   #767
Kronald_70GMC
Thanks, now I just need to figure out speaker sizes and locations and such. I've got lots of time to change my mind before I get speakers.
Kyle
Old 04-23-2022, 08:46 PM   #768
Kronald_70GMC
Alright so now that the skeleton is mostly complete until I figure out speakers and such, I figured I should decide how to do the corners. After some though between trying to make it out of sheet metal and fiberglass, I've landed on fiberglass. This could be interesting as I've never worked with it before. Any advice or tips would be appreciated. So far as I know, I should be able to apply some resin and some matting directly to my cardboard backing and just build up from there? Wish me luck.
Kyle
Old 04-23-2022, 10:19 PM   #769
72 tigger
72 tigger's Avatar
Do you want the cardboard to remain? Guess it wouldn’t hurt anything. Not a fiberglass expert, but I would recommend using adequate hardener in the resin. If you don’t, the resin remains somewhat gooey- not good
71 C10
72 K20
72 K10 Super
Kirk
72 tigger is offline   Reply With Quote
Old 04-23-2022, 10:20 PM   #770
72 tigger
72 tigger's Avatar
Skeleton looks really good!
71 C10
72 K20
72 K10 Super
Kirk
Old 04-23-2022, 10:39 PM   #771
Kronald_70GMC
I think having the cardboard remain is my best option. Thanks for the tip on the hardener. It would not be good if it was gooey at all. I'm considering painting these two corner filler panels and covering the box in the same carpet as the floor.
Thank you!
Kyle
Old 04-25-2022, 08:21 AM   #772
sakustoms
Unless you want the cardboard there permanently make sure to use a mold release agent.
Also, work in stages allowing the resin to flash off before adding more matting on top.
Looking good. Good luck.
Old 04-25-2022, 08:58 PM   #773
Kronald_70GMC
Thanks for the advice. I am planning to leave the cardboard there. I feel like it's alot of extra work to make it come off considering it will be on the back of panel and never seen. I am planning to head out there shortly and get the first layer of cloth down. I'll keep everyone posted on the results even if it flops.
Kyle
Old 04-25-2022, 10:25 PM   #774
Kronald_70GMC
Well I got the first coat of resin and cloth on. I won't say it turned out amazing but I think it will work after more coats and some matting. Here's hoping!
Kyle
Old 04-26-2022, 01:44 PM   #775
sakustoms
After you are done laying down matting get ready for body filler work. More spreading and sanding.
