Old 04-25-2022, 09:05 PM   #1
72farmer
Where to get 12VDC wire for electric choke?
I just put a new 2 barrel carb. with electric choke on my 79 C10. It had a hot air choke on the old original carb. I have got to find me a switched wire for the choke. Where would be the best place to look for a wire under the hood. Without having to run a wire through the fire wall and find one inside cab.
72farmer is offline   Reply With Quote
Old 04-26-2022, 01:04 AM   #2
cwcarpenter98
cwcarpenter98's Avatar
Re: Where to get 12VDC wire for electric choke?
I'm not sure about all the wiring specifics on a 79, but on my 63, I added an electric choke. I have it wired up with a relay so that the electric choke only functions when the engine is running. I used one of the wires off my alternator, but I'll have to go back and look as it's been a couple years since I did it. It has worked nicely for me
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 04-26-2022, 09:10 AM   #3
THI
Active Member
THI's Avatar
I used the windshield wiper motor 12v supply for the electric choke on my 1978
THI is offline   Reply With Quote
Old 04-26-2022, 10:16 AM   #4
72c20customcamper
72c20customcamper's Avatar
Not on my truck but I ran a wire from the fuse block ignition plug .
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 04-26-2022, 10:29 AM   #5
Corts60
Just here to tinker
Corts60's Avatar
Any switched source should be fine except the wire going to the distributor.
Old 04-26-2022, 04:26 PM   #6
Dead Parrot
Might see if there is a spare wire back where the oil sender normally sits, next to the distributor. On vehicles with electric choke, the choke wire often went though one side of the electric oil sender so the choke coil only got power when there was oil pressure. Might get lucky and the vehicle is already setup for electric even if it came OEM with a hot air version.
Dead Parrot is offline   Reply With Quote
Old 04-26-2022, 11:31 PM   #7
Just call me Sean
Just call me Sean's Avatar
Hot in run and start, but not in accessory.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 04-30-2022, 12:55 PM   #8
Pontiac1976
Pontiac1976's Avatar
I would check the fuse box to see if the choke option was hooked up, some time the choke option is on the fuse panel is dead other time it is live on one side you can tap in there.** use the proper fuse size on a spade tap fused wire to the carb. ( if your lucky your truck was hooked up wire was run not used it wrapped in the loom. But if was hooked the wire fire wall was not run you just read above wiring on the engine wire plug connector seal it up pop in fuse in factory fuse holder (choke location) your golden.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 04-30-2022, 05:06 PM   #9
hatzie
Moderator
hatzie's Avatar
You could use an oil pressure switch like the TBI systems have for the fuel pump power.
That way it only powers up when the engine is running.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 04-30-2022, 07:05 PM   #10
Just call me Sean
The carbureted ones work the same way, according to the wiring diagram.
