#26 |
![]() Join Date: Jun 2012
Re: Show your Rear Disc Brake Set Up
Does anyone know what year and model or a part number of the rotors that are used on the ebay kits? I need 5 ON 5. Thanks
#27 |
Soon, very soon.
1969 RS/SS Z10 Camaro Pace coupe 1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218 1979 Mazda RX7 1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary 1999 Honda Valkyrie 2006 Corvette Z06 2010 BMW 650i |
#28 |
Kit I used:
http://www.ebay.com/itm/230845329214...%3AMEBIDX%3AIT Someone told me a 98ish chevy front rotors. Worth going to local parts store to check...have them pull a few, can always get a refund.
72 Cheyenne SWB C10 (daily driver) (Super fake cause I just love the glovebox emblem) 70 Camaro RS (frame-off in pieces) 70 Camaro RS (daily driver backup) 69 Custom LWB C10 (son now drives) |
#29 | |
70 SWB 454/TH400 |
#30 |
Here's the kit from a forum sponsor ProPerformance, which utilizes Willwood calibers.
http://www.azproperformance.com/Pro1...Brake-Kit.html
#31 |
Here's mine. Did this awhile ago. They are Summit brand made by SSBC for an imapala. They are 5x5. If memory serves me right, I made a new axle bracket and they fit well. Here is a link, but it looks like they are no longer available.
#32 |
I used the 6-lug Tom's Classics kit from eBay as well.
1968 SWB Stepside "Bella coming home" "Bella's Build Thread" A master in the art of living draws no sharp distinction between his work and his play. He simply pursues his vision of excellence through whatever he is doing, and leaves others to determine whether he is working or playing. To himself, he always appears to be doing both. L. P. Jack |
#33 |
Im talking to auto city classic, they sell the kit on ebay. Im just trying to get a pair of drilled and slotted rotors that "match" my front rotors that I already have. I got my front rotors from POL but I dont know if the ones they offer for the rear disc kit are the same? Plus they want an arm and a leg for them!
Just FYI, if you purchase directly from Auto City Classic it is $10 bucks cheaper since they only charge $30 for shipping. Here is the 5 lug kit: http://www.autocityclassic.com/chevy...-rearc105ltrk/ Here is the 6 lug kit: http://www.autocityclassic.com/chevy...6-lug-rearc10/ |
#34 |
Anyone know what make/model they're using for auto city classic 5lug rotors ?
#35 |
captianfab is a member and puts together brackets for different set ups thi info was copied from his post.
Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE |
#36 |
Yeah I'm going to use his brackets. I'm just trying to figure out the easiest combo. I was looking at the caprice rotors but if I read correctly I would have to machine the rotors center section. And I'd like to have something with an e brake but doesn't the old cadillac calipers you have to use the e brake every time otherwise they go out of adjustment ?
#37 |
The impalla SS rotors slipped right on to my axle and the camaro rear brakes have the E-brake setup
#38 | |
#39 |
Time to contribute to this thread. I purchased my kit from CPP and it went together great! I got mine through their ebay store.
"ALWAYS SOMETHING" 1968 Chevy C10 SWB 383 SBC, TH350 Porterbuilt, Accuair suspension Last edited by Holliday; 02-16-2015 at 03:12 AM. |
#40 |
Old member
I bought the CPP kit as well. Upgraded to S/S hoses with slotted drille rotor's.
Installed new chrome 8" booster and master also. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#41 |
I have a set- up from tom's classic off ebay on my 68, great product, easy install and comes complete. Set two is on 67 is captain fab's set-up using 95 Camaro calipers, again great set up and bolted on easily. Just purchased a set up from pirate jacks for rear of wife's 66 nova and it is straight forward and easy. Toms and pirate jack both look to be from same company mbm and are well made. i have used two masters from cpp with built in prop valve and they work great. Master on 68 uses aluminum corvette master and cpp ( mbm) prop valve and no issue.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
#42 |
Are any of these kits 5x4.75? That's what I need for my truck 12 bolt rear end.
Once a Marine, always a Marine! My (Her) 57 Build "Beverly" My 66 Build "Betty" My 85 C10 "Old Blue" Help Me Find "Old Blue" OLD BLUE PART II |
#43 |
Does this count?
#44 |
"ALWAYS SOMETHING" 1968 Chevy C10 SWB 383 SBC, TH350 Porterbuilt, Accuair suspension |
#45 |
![]() Join Date: Jun 2014
Working on my setup now. Will post pictures once complete.
95 Camaro Rear calipers with e-brake Impala SS rotors Custom hard lines |
#46 |
Here's a front and rear view of my rear Wilwoods.
#47 |
13" 4 piston C6 Zo6 rear brakes. All brackets are from Tobin at Kore3.
#48 | |
edit, I found it. http://www.kore3.com/proddetail.php?prod=10277-01 |
#49 |
![]() Join Date: Mar 2012
[QUOTE=Andy4639;7050564]I bought the CPP kit as well. Upgraded to S/S hoses with slotted drille rotor's.
Andy, I realize this is an old thread, but did you have to order the E brake cable separate ?? I am assuming that you installed this in a LWB truck. I was looking at part number 6772RWBK-5-P12 the website states that a custom e brake cable must ordered for LWB trucks
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
#50 |
I doubt it for 2 reasons. Chevy/GM/Ford didn't do it on their "C" rears. And if you break an axle, the disc brake setup usually holds the axle in the housing
| Bookmarks |
