Old 04-25-2022, 11:34 AM   #2826
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Re: What did you do to your truck today.The 3rd chapter
Installed the front clip on Saturday, grille is temporary. This should be rolling in 2-3 months, what a long haul.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 04-25-2022, 11:57 AM   #2827
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Looking very good!
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 04-25-2022, 02:45 PM   #2828
72c20customcamper
72c20customcamper's Avatar
Picked up a 30 gallon oak keg for the 68 the keg was from a Winery in Oragon . Theme for the truck is going to be brewery related . As some know I’ve been brewing for over 20 years . I even had labels printed up at one time “Lackawack hill Brewing” so I’m going to use some live edge oak for the stake sides with the name on it .
Need to make some brackets for it and stain and or oil it
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 04-25-2022, 11:04 PM   #2829
allchevy58
allchevy58's Avatar
WOW! Nice job, hope to see it in person around Reno or Carson.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison
allchevy58 is offline   Reply With Quote
Old 04-26-2022, 06:18 PM   #2830
72c20customcamper
Finished up the “tank” for the 68 . Going to install it tomorrow the leather strap will hold it against the bulkhead of the bed ,just need to make up a bracket mount on the bulkhead . My friend always does a nice job and he won’t take money for small things like this . So I bought lunch for the shop. The fill is where the tap would go and the other is a vent , need to get some 1/4 copper tubing for that. And of course the fuel port is on the bottom it’s not at the lowest point of the keg and the bung is in the keg about about an inch so no crud should get sucked up . The base will be held down by the j bolts going to put a rubber pad under it to stop any squeaking. I stole one of my wife’s yoga mats she won’t notice I hope .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 04-26-2022, 06:55 PM   #2831
71CHEVYSHORTBED402
That would be awesome. And I'd like to see that beautiful truck man. Funny it's the same paint code as my C20, since repainted, hmmm. This dog loves oil. Stuff don't work, time ventilated and leaks, don't care. I like the wheels though, and fun to drive
Tony
Old 04-27-2022, 06:43 PM   #2832
Bubfn
Roads are finally ready to drive on. Got the car and trucks out today and ran them!
Bubfn is offline   Reply With Quote
Old 04-27-2022, 06:51 PM   #2833
Jiggers72-GMC
Jiggers72-GMC's Avatar
Great looking Chevy team there Bubfn, very nice.
Gerry, North Bay Ontario
1971 Chevy K10 short stepper, 518 med green & white
1972 GMC C1500 long box, dark Brown, owned since 1977
1969 GMC C2500 manual
Jiggers72-GMC is offline   Reply With Quote
Old 04-27-2022, 08:44 PM   #2834
72c20customcamper
The tank is in just need to hook up the gas line to the fuel pump . Had to drill a hole in the bed but it’s got a few natural holes in it anyway. The strap ended up just being a visual thing the j bolts hold it down solidly. And a friend that owns a brewery sold me three Jack Daniels barrels pretty cheap to. So the other one is going back . The JD ones are a little more aged looking and every time I walk by the truck it smells like bourbon. There’s a warning label on them about fire and the fumes . They drilled 2 1&1/4 holes an put in little button vents guess to air them out . I’m going to plug them with oak plugs .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 04-27-2022, 09:43 PM   #2835
Bubfn
Old 04-27-2022, 10:08 PM   #2836
71CHEVYSHORTBED402
A good day to install an instrument panel is a good day.
Tony
Old 04-28-2022, 12:04 AM   #2837
pjmoreland
pjmoreland's Avatar
Wow, Tony, that gauge cluster sure looks great.
I installed some spark plug wire holders today from an 80s van on the backs of the heads to go along with the 90s Vortec holders I have on the sides. The wires were just loose back there before, so this tidied things up.
pjmoreland is offline   Reply With Quote
Old 04-28-2022, 02:13 AM   #2838
71CHEVYSHORTBED402
Thank you, same under your hood. TBONE1964 restored that cluster say years ago.
Tony
Old 04-29-2022, 10:53 PM   #2839
CS1972
CS1972's Avatar
The hubcap / wheel saga has ended. No hubcaps, PO1's, SS dog dish and finally I'm nestled in with Rallys and bigger tires!
Ron
1972 Cheyenne Super 1/2 ton LWB 4x4 - Grapefruit Yellow / White
CS1972 is offline   Reply With Quote
Old 04-30-2022, 08:34 AM   #2840
Jiggers72-GMC
Very nice Ron, there's something about Rally wheels that look great on all trucks ......
Old 04-30-2022, 09:15 PM   #2841
CS1972
CS1972's Avatar
Dealer emblem + Neodymium (.5"L x .25"W x .06" thick, 1 magnet: 2lb pull) = my truck show emblem which I can remove whenever.
Ron
Old 05-01-2022, 03:44 PM   #2842
body bolt
Finally replaced the heater valve. In the summer I would just clamp it closed. It had been bad as long as I've owned the truck.
body bolt is offline   Reply With Quote
Old 05-02-2022, 08:29 AM   #2843
67C10Step
67C10Step's Avatar
Wife and I took the truck on its first on road spin since purchase. Wife purchased this truck for me for anniversary almost three years ago. It had sat in a shed for 12-13 years. Only went about 6-8 miles but all went pretty well for a first shake down run. No unusual vibrations or noises. Hearing a little valve train noise so an adjustment there is in the future.
Also, last items to get back on the truck are the inner fenders. I got the original from the left hand side sanded down and primed. Scuffing the new one I had to get for the passenger side (of course). Plan on painting them this week and maybe install this weekend.
Then it's off to the shop for an alignment after that and then windshield. Hoping to take the wife to our 28th anniversary dinner in it.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
Old 05-02-2022, 09:24 AM   #2844
mr.mud1
mr.mud1's Avatar
very cool,good looking truck.take care.
mr.mud1 is offline   Reply With Quote
Old 05-02-2022, 04:05 PM   #2845
72c20customcamper
Found the rear end noise . Left carrier bearing is toast .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 05-02-2022, 07:33 PM   #2846
Jiggers72-GMC
Yep, that will do it ..........
Old 05-02-2022, 08:12 PM   #2847
Ol Blue K20
Yep, looks bad, replace and go another 50+ years!
Dale
Old 05-02-2022, 09:45 PM   #2848
67C10Step
67C10Step's Avatar
But, that is the way I like my problems - obvious.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
Old 05-02-2022, 09:58 PM   #2849
Steeveedee
Who Changed This?
Steeveedee's Avatar
That's a real bummer. Hoping that the gears can be saved, or you just going to go through the whole thing? I'd replace everything, personally.
~Steven
Simi Valley, CA
Old 05-03-2022, 08:31 AM   #2850
72c20customcamper
Everything else is perfect the gears arent even showing wear and there was nothing in the gear oil not even glitter . I'm replacing all the bearings gears are staying .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
