Old 04-26-2022, 01:46 PM   #776
sakustoms
Re: My 1970 GMC “Project Splice”
Originally Posted by Kronald_70GMC View Post
Well I got the first coat of resin and cloth on. I won't say it turned out amazing but I think it will work after more coats and some matting. Here's hoping!
You are on your way now. No turning back.
Not sure what you are putting in there but if running subs make sure to put a port hole in there too.
sakustoms is offline   Reply With Quote
Old 04-26-2022, 09:05 PM   #777
Kronald_70GMC
Kronald_70GMC's Avatar
Tonight I went out and cleaned up the edges of my fiberglass. Once that was complete, I quickly sanded a few big ugly bumps out of it and did the second coat of resin with a layer of matting on the top portion of the piece. Matting is harder to work with and uses more resin so I didn't get the bottom section done.
Kyle
1970 GMC "Project Splice"
2017 Yukon Denali (Daily Driver)
IG: kyle_ronald
Kronald_70GMC is offline   Reply With Quote
Old 04-27-2022, 08:17 AM   #778
sakustoms
The last fiberglass project I did was a sub box I built for my kids car. I stretched fleece over it and covered it with resin. When that dried I applied fiberglass filler and then body filler. What a mess. LOL
Are you going to put filler over this and sand/paint?
Old 04-27-2022, 07:42 PM   #779
Kronald_70GMC
Yes it is for sure messy stuff to work with. I will either fill and paint or fill and cover in upholstery. I haven't decided yet.
Kyle
IG: kyle_ronald
Old 04-28-2022, 10:15 PM   #780
Kronald_70GMC
Last night I was able to find enough time to get out and do the second coat and matting on the bottom half. Tonight I removed the piece from the mold so to speak. Once it was free, I cleaned up the edges with my 3" roloc and flipped it over to do a coat of cloth on the back side. Now I will always have a part of my favorite beer and pop built right into the truck.
Kyle
IG: kyle_ronald
Old 04-29-2022, 10:44 PM   #781
Captain X
Captain X's Avatar
I'm kind of surprised you aren't using that space for tools or extra oil or coolant or what have you.
Captain X is offline   Reply With Quote
Old 04-30-2022, 10:24 AM   #782
Kronald_70GMC
I had considered it at one point but it is not accessible at all with the seats and console bolted in place.
Kyle
IG: kyle_ronald
Old 05-01-2022, 12:47 AM   #783
Kronald_70GMC
And here is a test fit with the weatherstripping.
Kyle
IG: kyle_ronald
Old 05-01-2022, 07:20 PM   #784
BigBird05
For access behind the seat since I moved the tank out back I got a 68 fold down seat.
BigBird05 is offline   Reply With Quote
Old 05-01-2022, 07:30 PM   #785
Kronald_70GMC
I also had thought about that too but I really want to use my factory buckets and console. I even contemplated trying to make my buckets fold down but that seems like it could get really dangerous quickly in an accident.
Kyle
IG: kyle_ronald
Old 05-02-2022, 11:29 PM   #786
Kronald_70GMC
I have applied the final layer of cloth on my piece and am starting to sand away all the ripples and imperfections. Depending what I do with this piece, as far as paint it or upholster it, will determine wether it will need fill or not. I really don't know what to do with it. I really think it's going to depend what I do for the box. For now I will take it to this point and decide when the time comes.
Kyle
IG: kyle_ronald
Old 05-06-2022, 10:36 PM   #787
Kronald_70GMC
I finished up sanding the lower portion to shape. Today I also picked up the fasteners I will use to attatch these corner pieces when I get that far. I also sat down and finally put an idea that I've had rolling around in my head to paper. I designed a logo for my truck. Not 100% sure where I'm going to use it yet but I have an idea. You will have to stay tuned to see it.
Kyle
IG: kyle_ronald
Old 05-13-2022, 08:30 PM   #788
ryans69chevy
Kyle, a few questions for you -
I'm trying to decide if I should close up some of the holes in my firewall on the cab. I know there are threads out there showing what hole is for what. Curious if you are going to go through all that work on welding up those holes or if you are just going to use rubber plugs?
Also, what type of primer and primer gun did you use on your cab. The more I look at my cab to figure out what stuff I can do, the more I realize its time to get a gun and material to shoot some 2k. It would be sweet to see your air setup. I should probably invest in some equipment to flush the condensate out of the line before it reaches the gun.
Your cab looks great. Can't wait to see more progress on this one.
ryans69chevy is offline   Reply With Quote
Old 05-13-2022, 09:04 PM   #789
Kronald_70GMC
Ok I'm going to try my best to answer your questions. As for my firewall, if you go back to page 9 post 211, that is where I started all my firewall mods. As far as what hole is for what, I essentially just plugged all but throttle, brake booster, column brackets and parking brake.
For the primer I used, it is called Upol High Build primer, I'll attatch a pic. The gun was one I borrowed from my dad. It is a gravity fed HVLP with the strainer screen removed or it doesn't spray primer well at all, nothing very fancy. My air setup is a 20 Gallon compressor that feeds into a second auxillary 20 gallon tank. From there, I run it into an air dryer, again nothing too fancy, it is one that doesn't use those little silicone beads or whatever they are. It works well for primer but if I was to paint with it, I'd likely have to make a few upgrades.
I hope this answers all of your questions. Thanks for following along with my very slow build.
Kyle
IG: kyle_ronald
Old 05-14-2022, 02:17 PM   #790
ryans69chevy
Holy smokes, I guess I didn't check in on thread as much as I thought. I missed a bunch of your updates to your cab. That looks incredible!
After checking at my parents house, I realized I have a bunch of parts that were sandblasted or all the paint is removed. I should probably get a gun and shoot those. I will probably have to stop at a paint store and get an air dryer, gun, and primer. Did you wet the floor or anything special when you sprayed in your garage?
Old 05-14-2022, 02:56 PM   #791
Kronald_70GMC
No I didn't I just set my exhaust fan on high and went to town. I figured if I get dust and stuff in the primer, it will get sanded away during blocking. That's the nice thing with primer, if you mess up, you just sand and it's good.
Kyle
IG: kyle_ronald
Old 05-15-2022, 07:57 PM   #792
Kronald_70GMC
Now that I have confirmed that my corner piece works as planned on the driver's side, I am able to start the passenger side. I got the cardboard all cut and fit and the first coat of fiberglass cloth layed down. Looks like it will be a nice mirrored image of the driver's one so at least I did something right.
Kyle
IG: kyle_ronald
Old 05-16-2022, 01:06 PM   #793
sakustoms
How do you like the Upol high build?
My son ordered this and I just got it yesterday. Hoping to spray soon.
Old 05-16-2022, 02:02 PM   #794
Kronald_70GMC
It's hard to say how much I like it so far. It sprays pretty nice so that's good. Haven't done any blocking on it yet so I can't say if it's any good in that respect as of yet. My dad has used it alot and likes it. I haven't used evercoat primers before but I like their fillers so I can't see that they would have bad primer.
Kyle
IG: kyle_ronald
Old 05-16-2022, 02:26 PM   #795
sakustoms
Let me know how it sands.
We pretty much use Evercoat exclusively at the shop. They make great products. Fortunately my brother inlaw has extra bottles of the activator that he is going to give me so my son didn't have to spend another $40 for that. This stuff is already expensive enough.
Old 05-22-2022, 08:14 PM   #796
Kronald_70GMC
Today I was able to "extract" the passenger side filler piece from the mould so to speak. I got a layer of cloth layed down on the back side so I will be ready to build up the front to the same thickness as the other side. Once I had that done, I stripped the old nasty cover off of the passenger side seat and repaired all the bent areas around both seat bottoms. I then got a couple of angle irons made up and bolted them to the bottom of the seat. My next move will be to temporarily weld on some steel rod to the angles so that I can place my seat and pull measurements for the rest of the brackets.
The first picture is what the seat bottoms looked like before straightening, they were both like this. The second picture shows after I had straightened the corner out. I'm not too sure if these seat foams are in "usable" condition or not but I would like to clean up and paint the seat frames and as far as I can tell, I have to completely ruin the foam to get it off of the frame? If there is anyone put there who has any info on this, I would be greatly appreciative.
Kyle
IG: kyle_ronald
Old 05-22-2022, 08:29 PM   #797
Kronald_70GMC
On a side note, it would appear that my buckets were originally in a blazer. You can see the holes were the fasteners held the back covers on and where they were touching the foam for many years.
Kyle
IG: kyle_ronald
Old 05-23-2022, 10:59 PM   #798
Kronald_70GMC
Tonight I got my driver's seat placed in the truck right where I'd like it to be. I welded a couple of "stilts" to my angle irons to get the proper height and angle figured out. Then I made like 842 reference measurments to get it sitting as square as I possibly could. After all that, I figured I better make some marks at the base of each stilt in case I bump it. I sort of have a plan of attack for the rest of the brackets so we will see how that plays out.
Kyle
IG: kyle_ronald
Old 05-23-2022, 11:22 PM   #799
Kronald_70GMC
Here is something to ponder....the base of the seat is sitting very square to everything on the floor yet if I stick a steel rod across at the metal frame between the top and bottom cushion, I have a difference of 5/8". And further so, the top of the backrest measures exact to the rear window pinch seam. Its almost as if there is a sight twist towards the center of the cab built into the bucket. Has anyone else ever noticed this? I thought that the driver and passenger buckets are identical but possibly not. I will have to re create what I've done here on the passenger side and see if I get the same measurments.
Kyle
IG: kyle_ronald
Old 05-28-2022, 10:03 PM   #800
Kronald_70GMC
Well that escalated quickly! I learned today that my bucket seat frame, possibly frames are bent. Possibly from an accident I'm thinking. So once I got the passenger seat in and saw how it was fitting to the rear window frame, out came the exacto knife and the seat foam was a goner. Well it wasn't quite as easy as that. For anyone wondering, it is not an easy or clean job. Once I had the foam removed from the frame and shredded all over my garage floor, I discovered the culprit. The twist in the backrest was extremely difficult to straighten but I got it straight again! There were also the two cross bars between the top and bottom of the seat that I had to straighten. Those were easy. I will have to re weld the broken spot weld and it will be good to go. It now fits very nice in the cab. Next will be the driver's seat foam.
Kyle
IG: kyle_ronald
