Old 07-27-2004, 10:17 PM   #1
72sleeper
[]D [] []v[] []D
bags and trailing arms????
anyone else ran into this bagging a coil truck i want to keep them on ay suggestions or pictures???
Clint
72 c'10 350ci/400hp
sleeper forever
72sleeper is offline   Reply With Quote
Old 07-27-2004, 10:43 PM   #2
XXL
Seņor Member
XXL's Avatar
Try here
XXL is offline   Reply With Quote
Old 07-29-2004, 09:25 PM   #3
68on22s
68 in progress
I put mine in the coil spot on the trailing on top of a smooth plate for it to lay on.drilled a 3 holes in the frame for the fitting/studs.works great with the supertrack bar kit and f9000s.
68on22s is offline   Reply With Quote
Old 07-30-2004, 12:02 AM   #4
Shane
Shane's Avatar
it is a simple "bolt-on" .... remove coils ... drill a few holes ... insert bag ... use correct size bolts
Shane is offline   Reply With Quote
Old 07-30-2004, 10:18 PM   #5
PrimeredThunder
Back from the Dead
PrimeredThunder's Avatar
Yep i've got bags on the stock trailing arms in the Stock location. With the Air Ride Technologies brackets you dont even have to drill any holes. But you're going to have to replace or modify your Panhard/Tracking bar to keep the rearend centered.
Kenny
The only Carb that matters to me is the one under my hood!
Salem, Oregon
PrimeredThunder is offline   Reply With Quote
Old 07-31-2004, 01:57 AM   #6
SCOTI
SCOTI's Avatar
Bags bolted in place of coils & 1.5" lowering blocks. . ...
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-03-2004, 01:13 AM   #7
MrShelley
Too Many Clubs Club
MrShelley's Avatar
I posted some pics of a bagged frame HERE.
The frame is a Blazer, but a truck suspension is practically identical.
Also, I will be posting a step-by-step air bag installation guide as soon as I receive my kit from ***************** and finish bolting my frame (68, shorty) back together. There seem to be a lot of misconceptions about air bags and air bag installation and I hope to dispel some of the voodoo surrounding them.
Hopefully I can start making the "guide" in the next couple of weeks.
How I installed my air bags...
MrShelley is offline   Reply With Quote
Old 08-04-2004, 12:12 AM   #8
soala70
soala70's Avatar
Mr shell what would be the reason for the "trick" spacers on the control arms?
bogey5
soala70 is offline   Reply With Quote
Old 08-04-2004, 06:29 AM   #9
LONGHAIR
The spacers are just a "clean" looking replacement for the stock type shims. You need more of them as you get to lower ride height to keep the wheels vertical. It's just a characteristic of un-equal length A-arms.
LONGHAIR is offline   Reply With Quote
Old 08-04-2004, 08:44 AM   #10
MrShelley
Too Many Clubs Club
MrShelley's Avatar
What Longhair said.
Old 08-04-2004, 11:15 AM   #11
Shane
Shane's Avatar
because stainless steel and aluminum is much kooler than stamped steel ... lol
