Just here to help
![]() Join Date: Jan 2002
Question about serpentine system.
I have a chance to get a setup off of a 89 burb and was wanting to know if it will bolt up to a 350(crate that came from Pace),and if there is something that i would have to do to make it work?Anyone done this?Any pics of the setup?Thanx guys.
Get a water pump for the serpentine system instead of v-belt. If ya don't, the water pump will turn backwards and not cool. Ran across this with V6 chevies in forklifts. Drives ya nuts till ya figure it out.
![]() ![]() ![]() LIFE AIN'T EASY WHEN YER FAT AND GREASY! GMC= Got More Class! ![]() ![]() |
Just here to help
Will it all bolt up ok besides the water pump?
To be honest, I've never tried it.
Got a serp belt setup off a 92 1500, bolted it right in place on a 76 400. If you have holes in the front of the heads it will work. Swap power steering fitting at back of pump. Reverse water pump as mentioned. Also need a reverse fan if you're using a belt driven fan. Brian
Take everything off the burb including accessories, braces and pulleys. You will have to probably drill and tap one hole in pass side head. Find a fan shroud off a big block.
Thats about it unless someone sees something I missed.
![]() ![]() 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
