Old 05-03-2022, 09:41 AM   #2851
chewychevy67
Re: What did you do to your truck today.The 3rd chapter
Originally Posted by CS1972 View Post
Dealer emblem + Neodymium (.5"L x .25"W x .06" thick, 1 magnet: 2lb pull) = my truck show emblem which I can remove whenever.
Can we see a picture of the magnet? I like this idea
chewychevy67 is offline   Reply With Quote
Old 05-03-2022, 10:46 AM   #2852
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Originally Posted by chewychevy67 View Post
can we see a picture of the magnet? I like this idea
x2
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 05-04-2022, 01:27 AM   #2853
Nima
Blue 67
Getting closer to finish line:
1953 GMC 3/4 ton: current project
1967 C20: 5.3 voretc with T5 conversion, 4 wheel 8 lug disc brake
1972 Nova: my 4 door sport sedan! 5.3 voretc + T5 conversion. drivable project, FUN!!
1979 Camaro Z28: 5.3 vortec conversion with build TH350: drivable project, Fun to drive
1992 Camaro RS convertible (Z28 clone): 5.3 conversion with build T5: on going project
2005 Silverado 2500, 4x4 Duramax, original owner
Nima is offline   Reply With Quote
Old 05-04-2022, 05:56 PM   #2854
72c20customcamper
72c20customcamper's Avatar
Installed the new axle bearing and seals . All the bearings are American made the grease seals were made in Mexico still better than China . I Also did the carrier bearings so much easier when you put the carrier in the -25 chest freezer for two days and heat the bearings up to 250 . Just slides together that’s frost on the ring gear .
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 05-06-2022, 09:53 AM   #2855
67C10Step
67C10Step's Avatar
Got primer on my inner fenders last weekend and yesterday took the time to put some paint on the under hood sides.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
Old 05-06-2022, 05:09 PM   #2856
72c20customcamper
Went to put the carrier in and after inspecting the right side shims they look like they were beat in with a punch and sledge hammer left was a thick solid spacer and it was cracked . I had noticed that the backlash was very excessive when I took it apart . I'm thinking it had slop the carrier bearings and someone beat a few shims to the right side tightning the bearings but causing the excessive backlash and put strain on the left bearing which finally failed.
So I bought a shim pack today and going to assemble tomorrow. Did the pinion bearings today ,the old ones looked good but better safe than sorry .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 05-07-2022, 12:27 PM   #2857
72c20customcamper
Calling it good 12 thousands for used gears is in the ballpark . When I took it apart it must have been 40 to 50 thousands lots of backlash
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 05-08-2022, 12:26 AM   #2858
Phillip Owings
Phillip Owings's Avatar
1972 C20 took apart the drivers side rear Brake Wheel Cylinder to clean up and a new Master cylinder came in today so will be installing it Soon.
Phillip Owings is offline   Reply With Quote
Old 05-08-2022, 01:35 AM   #2859
FleetsidePaul
R.I.P. E.S.L.L.
FleetsidePaul's Avatar
I sprayed WD40 on my crusty rear bumper brackets. ( All I had) Let that soak in. They've been there 50 years. Hopefully I can crack them and not have to break out the torch.
Shiny new bumper is on it's way. Thanks GMC Paul.
Paul. That's a nice name. I knew a guy named Paul. Oh wait a minute. That was me. Nevermind
1971 Custom C/20
1970 CST 20
1970 C/30 Flatbed
1983 C/30 Dually
2015 Corvette Z51 2021 Corvette Z51 1991 Cadillac Hearse 1982 Cadillac Eldorado Biarritz 2000 Porsche Boxster S 2020 Jeep Gladiator 1973 VW Thing 1973 Plymouth Satellite wagon 1963 Baja Bug 1959 Bug Dune Buggy 1970 Baja Bug 1987 Jaguar XJ 350.
R.I.P. El Jay
R.I.P Jessie.
R.I.P Grumpy.
Every day is a gift from God.
FleetsidePaul is offline   Reply With Quote
Old 05-08-2022, 08:19 AM   #2860
Jiggers72-GMC
Jiggers72-GMC's Avatar
Well done on the backlash, maybe go one more step and check the tooth contact pattern ........
Gerry, North Bay Ontario
1971 Chevy K10 short stepper, 518 med green & white
1972 GMC C1500 long box, dark Brown, owned since 1977
1969 GMC C2500 manual
Jiggers72-GMC is offline   Reply With Quote
Old 05-08-2022, 01:41 PM   #2861
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
Thanks to global warming and early HOT weather getting at or new the 100s already (which I am sure none of us are helping with out old trucks) I adjusted my idle for AC and shut off the heater water via my heater valve.
I think it was a smart move to put in that valve...
Richard
'72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT
SBC 350 | TH350 | LWB | AC | Buddy Seats
Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock
Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim
Rich72C10 is offline   Reply With Quote
Old 05-08-2022, 02:54 PM   #2862
Ekliptix
Ekliptix's Avatar
Got it on a lift in my new garage. Still working to get all my crap up on shelves to free up the floor space.
1972 Cheyenne Super SWB PS, PB, Tach, A/C, Tilt.
Drivetrain: Built 402BB, TCI Streetfighter 700R4, 2,500 stall, Eaton posi, 3.73. Suspension/Chassis: ECE 4.5/6.5 drop, CPP nitrogen shocks, CPP front and rear sway bar, CPP cross members. Exhaust: 3" exhaust with x-pipe, Spintech 3000 mufflers, Hooker ceramic coated headers. Best 1/4 mile time: TBD.
Ekliptix is offline   Reply With Quote
Old 05-08-2022, 03:10 PM   #2863
72c20customcamper
Mid 40s yesterday and 55 today . Early April weather here
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 05-08-2022, 10:12 PM   #2864
69Penka
Painted my front and rear bumpers white..
69Penka is offline   Reply With Quote
Old 05-08-2022, 11:20 PM   #2865
allchevy58
allchevy58's Avatar
Installed lift kit a couple weeks ago, my friend that painted the truck painted my new wheels and I installed new tires.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison
allchevy58 is offline   Reply With Quote
Old 05-09-2022, 12:10 AM   #2866
CastIron
CastIron's Avatar
I washed, then buffed out the original paint on the front of my truck today. Then I took it for a short drive.
CastIron is offline   Reply With Quote
Old 05-09-2022, 01:30 AM   #2867
Sheepdip
Sheepdip's Avatar
A while back I put new cab mounts on Otis, never understood why someone would go to all the trouble to pull the cab, paint it then re-install it on the old broken-down cab mounts? Maybe it's just me, anyway after the install I took it over to a fellow to completely re-align the doors, fenders and hood which he did a slam dunk job. Very thorough.
He also installed the missing rear inner fender bolts (one each side) that connects to the forward cab area.
After I picked up the truck, I had this definite pronounced clunk right underneath my clutch foot heel whenever the frame would flex from turning, pothole, approach etc. that was not there before.
It was about to drive me crazy trying to pinpoint it, I finally noticed that the sheet metal formed for the horn that the inner fender bolts to was just folded/mated together with no apparent welding spot or otherwise, so I drove a shim in it, and the clunk was no longer there. Bingo! Now I could slightly hear one on the passenger side but not as pronounced.
Got underneath and wire brushed down to bare metal, c-clamped it back together and welded the outer lip of what appeared to be about two 12 ga lips together both sides of the truck...whisper quiet now popping is all gone.
I borrowed this pic from another thread to show you the area I'm referring to.
Sheepdip is offline   Reply With Quote
Old 05-10-2022, 10:34 AM   #2868
NoStopN
NoStopN's Avatar
That's the kind of rear bumper I'd like to have for my truck. These "universal" bumpers from restoration sites look like they came from a Ford. Does anybody know of a company that sells something that looks like this?
1969 GMC 2500. 250 I6, 4-speed w/ granny low
NoStopN is offline   Reply With Quote
Old 05-10-2022, 09:09 PM   #2869
72c20customcamper
Took the 68 out put 50 miles on it . Ran great handles well only problem I ran into was the starter. Starts great cold won’t turn over hot nothing nada zip . Not even a click . Turned on the headlights had my friend hit the start and the lights go way dim battery tests good . Let it cool and starts right up. Ordered a new one be here Friday
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 05-10-2022, 09:29 PM   #2870
BASE
BASE's Avatar
I keep moving backwards. I really want to restore my truck to it's original 'medium blue poly' someday, and I decided it would be easier to get the firewall before I put the new engine back in... so now she's got a medium blue poly firewall.
'68 K10 496/465/205
BASE is offline   Reply With Quote
Old 05-14-2022, 08:32 PM   #2871
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
After procrastinating for the last 3 years and having no carpet in my truck as figured the minute the carpet was installed the 50 year core would start leaking and considering the fact of a new engine going in and redone rad the heater core would be the weak link in the cooling chain. So today started the Heater Core removal process. You have to take out the inner fender to get access to 2 of the 4 bolts that hold the core housing in place. The inner fender removal would be much easier if the truck was on a hoist. Tomorrow the core is coming out.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 05-14-2022, 10:03 PM   #2872
KQQL IT
At the body shop.
KQQL IT's Avatar
5 yrs since I bought the truck.
Mystery battery died
No date code I could see on it.
Old 05-15-2022, 12:10 AM   #2873
cab4word67
cab4word67's Avatar
I know the feeling, had to relpace my core on the 67 after it was all painted. But feel lucky, my 72 Buick Skylark required the fender to be removed.
cab4word67 is offline   Reply With Quote
Old 05-15-2022, 12:24 AM   #2874
Already Gone
I just pulled 2 of those Centennial Batterys out of my 1999 Cop Tahoe and replaced with new Kirkland ones, best price and no hassle warranty. I pulled them from another California Cop Tahoe I bought in 2012 and like yours no date code on them. They were still putting out 12.86 volts but being that old anything can happen. I park the Tahoe from October till April and always leave batterys on Battery Tenders.
Old 05-15-2022, 03:20 PM   #2875
hdrolling
hdrolling's Avatar
Installed rear shock relocation brackets, new adjustable pan hard bar. New 5" springs and removing the rivets now to install a C-Notch. Love my air hammer!
1972 C10 Step Side short bed
hdrolling is offline   Reply With Quote
