Old 05-05-2022, 09:15 PM   #11
Grumpy old man
Grumpy old man's Avatar
Re: What did you do to your truck today??
heat air control module went out a while back on my 95 k2500 . I found a good 95 module on ebay and actually had heat this past winter fast forward and now that it's starting to heat up I check and my A/C isn't working so after replacing the low pressure switch and I'm back to cold air again , Nothing better than a easy fix .
