#101 |
Re: '60-'66 Body On A '73-'87 Frame
As in posts #78 and #81 above. The overlay images.
#102 |
I also put a 80's c10 crossmember in and it was easy.
my 86 c10 build: http://67-72chevytrucks.com/vboard/s...d.php?t=496829 my 56 3100 build: http://67-72chevytrucks.com/vboard/s...09#post5712509 my 95 silverado build: http://67-72chevytrucks.com/vboard/s...35#post5879335 my gray 86 c10 http://67-72chevytrucks.com/vboard/s...34#post7624734 |
#103 |
https://www.youtube.com/watch?v=0YvaNo27VRA
I followed what this guy did and it worked out awesome. Very straight forward and way easier than swapping frames and dealing with all the mount relocations. Mostly, I had to drill 2 holes to locate (upper ouside, one on each side) and wallow out the other 4 on the vertical sides of frame and wallow out the 6 on the horizontal parts of the frame. Everything is seen on his video. Worked like a charm. He even shows how to do the PS conversion bracket and the Captain Fab booster mount. His videos are great.
#104 |
Now if I just had an original frame☹️
#105 |
Hey 51Chevyman,
I am in Lansing. Might know a guy with a frame. Send me a PM and I can get you the info. Dan |
#106 |
60-66 Nut
I did not post those, member LostMy65 posted those.
#107 |
But Found Her 25yrs Later!
I don't remember where I found them. I think I just googled frame schematic by year and make.
#108 |
Ok, Thanks.
Just searched. Info can be found hear 1999 and newer chevy trucks. https://www.gmupfitter.com/ Last edited by djnordeen; 08-03-2018 at 09:07 AM. |
#109 |
Not sure if this was mentioned, but the 73-91 Suburban Frame is a much better fit, it does not kick up under the cab...and wheelbase is close to our longbox ....they even make a kit to use this chassis, EZ chassis swaps in Minnesota makes it. I am surprised there is not more discussion on this.
#110 | |
#111 | |
1960-1966 Chevy/GMC Long Bed Uses the 1973-1991 Suburban Chassis Kit bolts onto the 1/2-ton & 3/4-ton Suburban chassis. 2WD or 4WD. What's included Firewall Insert (Mounts brakes, fuse block, throttle cable, etc.) Front Bumper Brackets (Adapts bumper mounts to frame) Front Cab Mounts (Attaches to Suburban cab mount holes) Front Radiator Support Brackets (Mounts original radiator support to frame) Upper Steering Column Bracket (Mounts steering column under dash) Front Bed Mounts (Located by Suburban frame holes) Rear Bed Bushings (Mounts rear bed supports) All Mounting Hardware Included (Bolts, Washers, Nuts, etc.) All Bolt-on Parts are Powder-Coated Specifications Kit Price $849.00 Flat-rate S&H* $200.00 Chassis Used 1973-1991 Suburban Attachment Type Bolt-on *Rate applies to 48 contiguous States. Please contact us for pricing on other shipping locations.
#112 |
Does anybody know of anyone who has used a suburban?
#113 |
![]() Join Date: Mar 2011
Ky-donzi did.
http://67-72chevytrucks.com/vboard/s...d.php?t=537789
63 k20 with cummins 4bt, owned sence 1982 |
#114 |
Here's a video that does a good comparison between the 67-72 and the 73+. Remember, the frame of the 67-72 are very similar to the 63-66.
https://youtu.be/dahVzNjZoHQ
#115 | |
| Bookmarks |
