#226 |
Re: project "C10 Fever" (68 factory black 396 swb)
Those inner fenderwells look unreal
'68 C20 Utility 396 4sp (BuildThread: http://67-72chevytrucks.com/vboard/s...d.php?t=806904 ) '68 C10 50th |
#227 |
![]() Join Date: Jan 2007
Truck is ready for to take to the shop for exhaust, then it's cam break in time! Can't wait to get this on the road again.
Project "C10 Fever" (68 factory black 396 swb) Project Faded Glory (71 c10 med bronze original paint refresh) Project "Little Sister" (70 c10 blue original paint refresh) Project "Blue Bomb" (70 c30 blue original paint refresh) SOLD Project "Vitamin C" (71 c10 orange original paint refresh) SOLD |
#228 |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
It's looking very nice.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
#229 |
Re-tubed the driveline. Just needed an extra inch.
But it had to be done right...Tomorrow its off to the exhaust shop.
#230 | |
![]() Join Date: Dec 2012
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO GO!!!
#231 |
Wow I feel much better about my 30-min drive each way now.
![]() 55” c-c
#232 |
I can't believe it's been almost a year since I posted an update.
We moved in September, and I've been working on house projects in all my spare time. Just before moving, I tried to get the cam broke in. Had a few bugs to work out, and didn't have time to do it then. So the truck went into storage. Got it out today, hoping to get back on track making it road worthy soon...
#233 |
Making some new friends...
#234 |
...life gets in the way of these projects some times. Glad to see you're back at it
![]() I'm in the midst of a garage build, so the projects have pretty much come to a screeching halt
#235 |
Well I finally finished the cam break in. Had to switch back to a mechanical water pump, fix a fan relay issue, repair a burned temp gauge wire, and some frustrating hose and belt fitment issues. Seems to start, stop, and idle nicely. Nice lope to the idle
![]() Now I have a ticking sound at the passenger head (valve adjustment hopefully), an oil leak, and the trans wont go into gear now. Hmm. So more punch list items, but making ssllooooww progress.
#236 |
Heres a preview of my custom a/c delete plates. I made them to imitate the vintage style of the heater delete plates
#237 |
Nice work. they look great
#238 |
#239 |
Update:
After the cam break in, the 700r4 wouldn’t go into gear. It worked fine before I pulled the 305. So I figured it was something simple. Took it to the trans shop for a diagnosis. They called me today and apparently I smooshed something when I installed the engine. I’ve always said I know just enough about cars to get myself into trouble… Time for a rebuild, shift kit, and stall converter! Sad/happy…
#240 |
![]() Join Date: Jul 2008
Subscribed! Looks like a your making good progress. Interior is looking sharp. That’s too bad about the Trans though!
1965 c/10 swb 1969 c/10 lwb
#241 | |
Keith SOLD - 1963 C10 Short Fleet 350/700R4 4/6 drop 1967 GMC Super Custom - Short Fleet COPO concept w/427 BBC T-400 w/Doug Nash overdrive 4/6 Drop, Buddy Buckets, etc... Frame Off (In Progress) I call it "Vulgar Display of Power" 1980 Silverado Original paint 49k Original miles 4/6 drop Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941 |
#242 |
Right on. I'll post a pic when I get them installed. Yeah, that's an original heater delete plate.
#243 |
![]() Join Date: Jun 2005
hi tim, any updates?
Brian XNGH ECV Chapter 58 1972 Jimmy / Blazer Project 2wd 1974 Chevy Crew Cab Shorty |
#244 |
Well hello there Brian.
Im hoping to have some updates soon, coincidentally. Still at the trans shop since my last post. Supposedly it was finished a while ago but wasnt shifting right so the shop is troubleshooting. Here is my punch list once I get it back: *Fix oil leak *Valve tick pass side *Fine tune timing/carb *Change oil *Alignment A-arm clearance A-arm touch up Finish/install ac delete plates Replace lamp harness Reassemble fenders, grille, hood
#245 |
Well the shop is done with the truck. Turns out the valve "tick" was my rocker studs coming loose. Got that fixed. Should be getting the truck home next week so I can start working on getting the front panels installed.
#246 |
How did I get this OLD!
![]() Join Date: Dec 2014
Any more progress pics?
1967 Oshawa built LWB Fleetside. 327,3 OTT, 515 Vermilion, CST, PS, PB, Shoulder Harness, Mechanical Diesel Tach, Vac, Kilometre Speedometer, Speed Warning, Choke Delete, Manual Throttle, Fawn interior. Dealer installed A/C 04/2015, N34 Rosewood Steering Wheel 06/2023 Members who I have met personally. Metaldoc, chevnkevin, 62 Longbed, 72LHorn, 72MARIO, YBNORML, TBONE1964, Classic Bowties, Chevemall, Dagnabbitt, Chewychevy67. |
#247 |
Unfortunately no progress. But I did get it home.
#248 |
#249 |
![]() Join Date: Apr 2008
Very cool truck
71 C10 72 K20 72 K10 Super Kirk |
#250 |
Well, after a very very long time, I still havent done much.
I did pull it out and hose it off. I installed my custom AC delete plates.Im actually going to remove my fawn interior and install new red vinyl. Ive been wanting to do that for a long time, just needed a little nudge so here we go .
| Bookmarks |
