Speedo cable length
Hello,
Does anyone know the factory length for a speedo cable in a 1972 K10 backed by a 4 speed. I’m looking for one . Thanks much
Some progress is better then no progress |
![]() Join Date: May 2022
Re: Speedo cable length
Maybe this one will work.
https://www.classicheartbeat.com/pro...dometer-cable/ |
![]() Join Date: Nov 2018
If all else fails get you a 3/8" rope, rubber fuel line or what ever you got.
Route it, mark it, then pull it out and measure it. |
Thanks sir
You can get almost any length speedometer cable on Amazon. Saves the shipping. Last one I purchased took two days to arrive and cost less than $12.
4wd cables are longer than 2wd drive, because they screw into the transfer case.
Think I got an 83" for my K20, it was in stock at local Autozone, Pioneer brand part # CA-3004 for around $10.
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432 '85 K30 "Big Nassy" [B]'85 C10 [B] "Corpse" '01 2500 Suburban ...party wagon & tow truck '06 Silverado SS...DD '06 C1500 WT...DD '07 Classic C1500 WT...DD Built & sold cause can't keep 'em all: '72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190 '55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938 '69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541 '86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619 Last edited by fun in dirt; 05-23-2022 at 10:00 AM. |
Thank you
| Bookmarks |
