Old 05-26-2022, 07:38 AM   #1
52napco
Firewall insulation that actually fits
Looking for input on a pad that actually fits and looks correct.
Any input is appreciated thanks
52napco is offline   Reply With Quote
Old 05-26-2022, 07:50 AM   #2
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: Firewall insulation that actually fits
Contact Wes at Classic Heartbeat. He was getting a correct US made repro from a family run operation. The more widely available repro pieces look awful imo.
Old 05-26-2022, 07:53 AM   #3
Grumpy old man
Grumpy old man's Avatar
Repops , It's what they do .
https://www.67-72chevytrucks.com/vbo....php?p=8825200
http://www.repops.com/product-search...102&yr=26&ne=0
Old 05-26-2022, 08:44 AM   #4
Accelo
Accelo's Avatar
I have a bunch of it laying around because it didn't fit. I used the "stick on" cab sound insulation. Likely not as effective for heat as the factory stuff. But at least I could cut it and it fit.
Accelo is offline   Reply With Quote
Old 05-26-2022, 01:53 PM   #5
52napco
I ordered the repops pad from jegs..
Hopefully it's as good as their reputation
Old 05-26-2022, 09:43 PM   #6
jumpsoffrock
Can you find a part number? I wasn't able to locate any firewall pads for a 67-72 chevy truck on Jegs site.
jumpsoffrock is offline   Reply With Quote
Old 05-27-2022, 06:50 AM   #7
52napco
Order from Wes if possible..I think he sells the best USA made pad...
The Jegs/repops numbers are CT1190 for ds , CT121 for 71&72 center and CT120 for 67-70
Old 06-07-2022, 09:33 PM   #8
52napco
Got the repops insulation installed and between better quality and more experience it fits great...thanks for the heads up.
Old 06-07-2022, 10:01 PM   #9
jumpsoffrock
What was the total cost? How many pieces is it? AC or without AC?
Old 06-07-2022, 11:24 PM   #10
cericd
cericd's Avatar
How close is the quality of the repops to that of the original pads? Could you show any comparison or installed pics? Thanks.
Chris
My 1970 SWB C/10 - https://67-72chevytrucks.com/vboard/...d.php?t=534872
cericd is offline   Reply With Quote
Old 06-08-2022, 07:04 AM   #11
52napco
Truck has ac and was 2 pieces... approximately $90 with shipping
Old 06-08-2022, 07:59 AM   #12
CarlsLQ9SS
CarlsLQ9SS's Avatar
Does anyone make them for factory air condition? I can find the passenger side without ac but no luck for the ac truck
Carl
1971 GMC short bed, (Henry)
Options I've added, tilt, ac, 8k tach,
Electric speedometer conversion for LS swap,
6.0 with 823 heads and BTR stage 4 truck cam,
4L80e, posi with 3.73 rear end,
Power steering and power brakes
Lowered 5/7. Frame up build.
CarlsLQ9SS is offline   Reply With Quote
Old 06-08-2022, 07:44 PM   #13
jumpsoffrock
^^^I don't believe there is a mat for passenger AC trucks, thats why they can't be found. I seem to remember coming to that conclusion a few months ago when I looked.
Old 06-08-2022, 08:18 PM   #14
52napco
Correct...no pad for passenger side
Old 06-20-2022, 10:45 PM   #15
davischevy
davischevy's Avatar
I'm late to this party. Repops pad made in the USA.
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 06-20-2022, 11:26 PM   #16
cericd
cericd's Avatar
Thanks Larry, looks like nice stuff. Would you say the quality & fit is on par with the OEM stuff?
Chris
Old 06-20-2022, 11:32 PM   #17
davischevy
davischevy's Avatar
I was very happy. I used original retainers.
other Larry
Old 06-20-2022, 11:47 PM   #18
cericd
cericd's Avatar
Nice, do you remember where you ordered them from?
Chris
Old 06-20-2022, 11:57 PM   #19
Hatzman
Hatzman's Avatar
Has anyone used dynomat and then tried installing the pads as well? Do they fit and stay where they need to?
Thanks!
Steve
___________________________________
http://67-72chevytrucks.com/vboard/s...d.php?t=618848
Hatzman is offline   Reply With Quote
Old 06-21-2022, 07:55 AM   #20
sick472
sick472's Avatar
I used sound deadener on my fire wall and covered that with a pad from GMC Pauls. It worked like I expected, very well. I opted to to use SS button head bolts to secure the pad, but that was just for a fancier look from the engine bay. The OEM retainers would work fine to. They have more than enough reach to accommodate the extra thickness of the sound deadener and then some.
He who is without oil shall throw the first rod. Compressions 8.7:1
1972 C10
1976 C10 (parts truck)
1985 K20
sick472 is offline   Reply With Quote
