Old 05-29-2022, 10:48 AM   #1
weim55
Correct power steering hoses 1973 350 C or K?
I have a truck with no PS hoses whatsoever. It does have all the correct original power steering pump and brackets. Could one of you provide pictures of an original: 1, The hoses from the steering box over the frame and 2, approximate hose configuration at the pump?
Looking at pictures of units available in the aftermarket these are all over the boards in pictures of an original configuration would be a big help towards attaining the right pieces. If any of you have experience with a vendor with the correct units that would be helpful as well.
Steve weim55 Colorado
weim55 is offline   Reply With Quote
Old 05-29-2022, 03:21 PM   #2
Pontiac1976
Pontiac1976's Avatar
Re: Correct power steering hoses 1973 350 C or K?
Hello there it would be easier if you showed your Motor and bracket front, and pic from steering gear hose to the bracket. Then most can help you get the right set for your parts. Oh any 1980 up hose fitting or pump / gear will have MM o-rings. 73-79 SAE.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 06-05-2022, 02:39 PM   #3
chris989
I stopped messing with any OE hoses and starting making my own using steel AN fittings and braided line. There is every adapter needed to get from the metric oring stuff to AN.
It may seem overwhelming for the fit one but I promise is it easy. If you wheel way out in the middle of nowhere a few fitting and a length of hose in your tool kit fixes just about anything on the spot.
Chris
chris989 is offline   Reply With Quote
