View Poll Results: Which direction to take?
Replace damaged harnesses with good, used GM ones 7 58.33%
Get an aftermarket kit to rewire the entire truck 5 41.67%
Voters: 12. You may not vote on this poll
Old 05-24-2022, 11:08 PM   #1
cwcarpenter98
cwcarpenter98's Avatar
Chewed up wiring harness, what would you do?
I have a dilemma, and would like to get some input on the situation.
The 81 I'm getting has a ton of wires chewed through under the hood, and I need to make it right. Everything in the cab seems fine as I didn't see any rats nest material in the cab. I don't know what the wires look like under the bed and such, but I wouldn't be surprised if some have been chewed.
Goals for the truck is to keep it mostly stock. Maybe I'll swap to a 4 barrel and throw a cam in the 305. Definitely thinking about lowering it some. I don't have plans or a desire right now to LS swap. If I do decide to engine swap, it'll most likely stay sbc powered because I like them
So what would y'all do?
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 350, Saginaw 4 speed
Old 05-25-2022, 12:00 AM   #2
mongocanfly
mongocanfly's Avatar
Re: Chewed up wiring harness, what would you do?
Holy cow...now that theres a rats nest...or squirrels...or whatever
as old as the truck is , I'd be tempted to just replace all the wiring, inside and out..theres no telling what all kinda po stuff went on inside the cab as well..
Then itll be all new and no worries..
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 05-25-2022, 02:32 PM   #3
cwcarpenter98
Yeah, definitely was something large up in there for awhile!
I guess I should have mentioned that this truck has had zero modifications that I have been able to find from the previous owners. There's no aftermarket accessories added to the interior. It's also a possibility that the truck only has 57k miles based on the previous owner's story. It's also possible that it's been 157k, but either way, was definitely kept in good condition until it got parked for 20 years in a field.
I was very surprised that the engine would still crank with the "key". Can't find the key currently, but the ignition cylinder was still able to turn and it turned the engine over Also, the battery warning light came on and the door buzzers still worked.
I got 12 volts to the distributor, but as seen in the second picture, the distributor wires were chewed through, so no spark out to the chewed up spark plug wires.
Christian Carpenter
Old 05-25-2022, 03:25 PM   #4
JJH Jimmy
JJH Jimmy's Avatar
If the wire harness under the dash is good there is no reason to replace it. An aftermarket wiring harness like american auto wire is going to cost close to $1000. I would either build your own or buy an engine bay harness.
If the truck is truly untouched building your own would be fairly simple. I just built one for my K20 and probably have $100 in it. I got good automotive GXL wire from wirebarn.com and delphi terminals from amazon. You will have to buy the delphi crimpers for the terminals.
1972 GMC Jimmy 4x4 LS Swap
1985 Chevy K20
1994 GMC Yukon
2021 GMC 2500HD Duramax AT4
My "It's a Jimmy Thing" Build
http://67-72chevytrucks.com/vboard/s...d.php?t=583528
Budget Build 1985 K20
http://67-72chevytrucks.com/vboard/s...d.php?t=801565
JJH Jimmy is offline   Reply With Quote
Old 05-25-2022, 03:30 PM   #5
JJH Jimmy
JJH Jimmy's Avatar
Also, i didn't vote because I wouldn't buy a new harness and finding a good used engine harness will be next to impossible!
1985 Chevy K20
1994 GMC Yukon
Old 05-25-2022, 04:45 PM   #6
Dead Parrot
My vote of used was based on finding a good use harness. That is getting harder as the supply of decent salvage yard squares is about done. A big problem with used is getting a harness that is a good match to your truck's equipment.
Dead Parrot is offline   Reply With Quote
Old 05-25-2022, 09:41 PM   #7
cwcarpenter98
I didn't think about building my own engine harness. That's definitely something I'll need to look into. How much wire did you need to finish your K20?
Definitely a challenge, especially since I'm going to need a harness for an 81 or 82 truck with A/C
Christian Carpenter
Old 05-25-2022, 10:49 PM   #8
JJH Jimmy
JJH Jimmy's Avatar
This should get you close
25’ of red 12 ga
25’ of red 10 ga
25’ of purple 12 ga
Multiple color pack of 14 ga
Mouser ring terminal kit
Packard 56 and 59 male and female terminals
Couple feet of 16 ga fusible link wire
Assortment of shrink tube
Wire loom
Harness tape
1985 Chevy K20
1994 GMC Yukon
Old 05-27-2022, 10:35 AM   #9
cwcarpenter98
25’ of red 12 ga
25’ of red 10 ga
25’ of purple 12 ga
Wire loom
Harness tape
Thank you!
Christian Carpenter
Old 05-27-2022, 12:48 PM   #10
Dead Parrot
Consider getting one of these to replace the existing junction point. Out of a 90's truck. Get the associated wires as well for the factory fusible links. Bonus of a heavier main alt wire if you upgrade to a 90+ amp 12SI. This was about $10 from the local Pull-a-Part a couple of years ago.
Old 05-29-2022, 07:47 AM   #11
bhc41051
bhc41051's Avatar
An OEM style engine harness is $288 from American Autowire. https://www.americanautowire.com/sho...harness-143825
bhc41051 is offline   Reply With Quote
Old 05-29-2022, 11:14 AM   #12
Getter-Done
Getter-Done's Avatar
Check out this place.
They are probably pretty close to you.
Coach Controls, Inc.
4250 Spring Place Rd SE
Cleveland, TN 37323
I made a visit down there.
The guy is very Knowledgeable.
Link: https://coachcontrols.com/index.php?...index&cPath=41
The early bird gets the worm,
85 Chevy K-20
Getter-Done is online now   Reply With Quote
Old 05-29-2022, 12:24 PM   #13
kwmech
I would just rewire it myself from the bulk head out. Not much wiring needed to make it run.
Old 05-29-2022, 10:41 PM   #14
cwcarpenter98
Good to know, thanks.
I did see that, but when you also add the $275 for the headlight harness that also has rodent damage, that makes it a little tougher to pull the trigger on it.
Cleveland, TN 37323
Thanks, that's also an option to consider.
I'm thinking about it, but definitely a back burner project for now, so I have plenty of time to think
Christian Carpenter
Old 05-29-2022, 11:22 PM   #15
Pontiac1976
Pontiac1976's Avatar
(JJH Jimmy)If the wire harness under the dash is good there is no reason to replace it. An aftermarket wiring harness like american auto wire is going to cost close to $1000. I would either build your own or buy an engine bay harness.
I agree part one, part two most of that I would go along with since Canada have not used wirebarn.com so I would take his word no that.
Now I would unplug engine connector @ the firewall disconnect un clip all clips unplug all connector unbolt starter, ALT, sensor plug sending units. then buy or get wire in lengths to match the harness you took of. Make sure you mark all the wire and where go and take pic before and after the wire run. Now if your putting in a LS then you will have to mod your factory engine harness any way. As far as I know you can not get the engine firewall end connector you will have to de-pin that one reuse it.
https://bowtieguy.proboards.com/thre...ness-bulk-head
https://bowtieguy.proboards.com/thre...d-lights-front
This may help you or not.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
