![]() Join Date: Jan 2001
Location: Katy, TX...but the love of my life resides in Dublin,OH.
Transmission Linkage?
Can anyone direct me to a website where I can purchase the transmission linkage for a turbo350? I don't feel like going to every salvage yard on the planet to end up with the same worn out piece that I have. I have a 71 SWB that was a three speed on the column. I used a column from a 71 LWB. The rod that went from the column to the tranny linkage was too short? I fabricated a rod to serve this purpose with a piece of all-thread. My problem now is the lever and the selector on the transmission are worn severely and cause alot of slack in the column. Do I have to use the same thing or can I use something from a later model truck? Thanks for any advice... I recently moved and all of my catalogs are still in storage.
It's a juckyard or find some parts from other board members. Other than that you could switch to the Krugall linkage.
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html " TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410 </A> |
CCRider
When I did mine I just welded up all the worn pieces. If you don't weld maybe you fine someone to do it for cheap. I have also heard that it not hard to adapt 73 up linkage,might not be as hard to find in a boneyard.
72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS |
What pieces do you need. I just converted to a B&M Light Truck Megashifter. (Highly recommended!) I could send them to you if you pick up the shipping. Don't know what shipping is but I could find out for you if interested?
68 SWB The Surgeon General doesn't say anything about smoking a Ford!!! Would rather be ran over repeatedly by a Chevy than drive a Ford!!! Paralyzed from the neck up and confined to a hat! Kathleen, Georgia USA |
![]() Join Date: Jul 2000
Kugel is the way to go!
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
![]() Join Date: Mar 2000
Did any of you guys install the Kugel linkage? If so, any mods required. Did you need the long or short rod?
Many thanks. Peter |
Thanks for the Advice... I think I'll try this Kugel linkage.. I am concerned with the length though. The rod I took off that other 71 was 23" long and it seemed too short...maybe I didnt do something right I'll have to investigate further. But, for 40 bucks I can't go wrong... I can always recover most of that if it doesn't work out for me.
Thanks again, Darryl |
