Old 05-27-2022, 03:28 PM   #2901
Jiggers72-GMC
Jiggers72-GMC's Avatar
Re: What did you do to your truck today.The 3rd chapter
Agreed Mike, I'm on this forum everyday looking for info .......
Gerry, North Bay Ontario
1971 Chevy K10 short stepper, 518 med green & white
1972 GMC C1500 long box, dark Brown, owned since 1977
1969 GMC C2500 manual
Jiggers72-GMC is offline   Reply With Quote
Old 05-27-2022, 07:59 PM   #2902
pjmoreland
pjmoreland's Avatar
The 15x8 rally wheels I had on the front of my truck were rubbing on the fender openings when I'd hit a dip in the road. Lolife recommended Stockton Wheel to have them reduced to 15x7, so that's what I did. They cut the centers out of a set of 15x8s and welded new USA-made hoops on them. Took them one week. Finally installed them today.
pjmoreland is offline   Reply With Quote
Old 05-27-2022, 08:57 PM   #2903
MrBlue
MrBlue's Avatar
Installed the 99 Tahoe seats after replacing the leather with something in black. Still need to smooth the leather, but love the look.
MrBlue
72' C-10 350 TKO-600 Current Project
54' Ford F-100 Life Long Project
MrBlue is offline   Reply With Quote
Old 05-27-2022, 10:51 PM   #2904
Sheepdip
Sheepdip's Avatar
Been around a long time, started out making wagon wheels. I believe they are in their original location still on Fremont St. across the water from the Port.
Sheepdip is online now   Reply With Quote
Old 05-27-2022, 10:52 PM   #2905
D.B
D.B's Avatar
Your truck is looking nice and the wheels look great. I thought Stockton Wheel went out of business. Glad to see they are still going. I sent my 8 lug factory rims out to them back in 94 so they could install the centers into wider rims. So I have 16x8's in front and 16x10's out back.
I was out at the C10 Nats a couple of weeks ago and I was showing people your dummy gas cap neck that I have on my 72 C20 and everyone liked it. Hopefully it will get you some sells on them. Keep up the good work!!
D.B is offline   Reply With Quote
Old 05-27-2022, 10:56 PM   #2906
pjmoreland
pjmoreland's Avatar
Thank you!
Old 05-27-2022, 11:00 PM   #2907
Willowrun
Willowrun's Avatar
2wd square blazers came with 15x7 rally wheels from the factory. What backspacing did you go with? Wondering if it is the same as the factory 15x7's.
Old 05-27-2022, 11:02 PM   #2908
pjmoreland
pjmoreland's Avatar
I went with 3-7/8", which is the same as the 15x8 6-lug rally rims. I did that because I knew they would clear my lower control arms without trimming them.
Old 05-30-2022, 07:20 PM   #2909
72c20customcamper
72c20customcamper's Avatar
Started the stake side for the 68 anniversary truck . Some of the slab leftovers I usually cut up for firewood . These are hickory I’m going to just but a slab on each side . Also will have to bow tie some of the end cracks before I finish sand them this week all I did today was send them through the planer.
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 05-31-2022, 08:31 AM   #2910
BASE
BASE's Avatar
I've got a few different projects going on with my truck at the moment. Replacing inner/outer rockers is one of them. I noticed the cab wasn't lining up with the bed at all a few days ago. DS was ~1 low, PS was fine. I was worried something moved while I had the cab cut up. A few days later I went out and measured the body mounts on both sides, they were identical (~2" for the rears). As I was scratching my head I walked around the truck and noticed the PS was now ~1" low as well.
New body mounts fixed it right up but I'm still a little puzzled why both of the rear cab mounts collapsed ~1" while sitting in my garage after 54 years of driving around. Seems unlikely, but I looked at some recent photos, and they seem to confirm I'm not losing my mind. It was sitting just fine a few weeks ago.
In other news, I finally got catainfab's booster mount and PS frame adapter installed. Both of those items were $ well spent and I'm sure saved me a lot of work & head-scratching.
'68 K10 496/465/205
BASE is offline   Reply With Quote
Old 06-01-2022, 01:20 AM   #2911
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Finished installing the body, moldings and inner fenders. She's close to done, but no sign of windows yet.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 06-01-2022, 11:52 PM   #2912
hdrolling
hdrolling's Avatar
Test fit the new bed, ready to remove/disassemble and paint.
1972 C10 Step Side short bed
hdrolling is offline   Reply With Quote
Old 06-02-2022, 01:55 AM   #2913
BC10
BC10's Avatar
I am digging it. Do your rear fender lights have chrome trim around it?
BC10 is offline   Reply With Quote
Old 06-02-2022, 10:15 AM   #2914
paul blair
Looks good hdrolling. Bed kit? Just wondering if the assembly went ok or any problems.
paul blair is offline   Reply With Quote
Old 06-04-2022, 04:01 PM   #2915
hdrolling
hdrolling's Avatar
More of a polished but yes they do.
Old 06-04-2022, 04:05 PM   #2916
hdrolling
hdrolling's Avatar
Yes its all Keyparts with a Mar-K white oak wood floor. Went together okay but you have to assemble and put it on the truck before any paint, I had to re drill a few holes and I still need to elongate a few after I take it apart. Not bad but I would have been upset if I would have painted everything first.
Old 06-04-2022, 04:22 PM   #2917
BC10
BC10's Avatar
I love them! Which place did you order yours from?
Old 06-04-2022, 09:13 PM   #2918
hdrolling
hdrolling's Avatar
I just them off ebay, search New Clear Lens Deluxe Side Marker Light Set W/ Trim For 68-72 Chevrolet C10.
It was like $30 for two
Old 06-05-2022, 09:10 AM   #2919
BASE
BASE's Avatar
I'm not really getting off to a fantastic start with my brake lines. I spent about 4hrs making the two short lines that connect the master to the prop valve. And yes, I did forget to put the fitting on once, and then put the wrong size on the next try. Decided it was time to cool off and try again another day.
'68 K10 496/465/205
Old 06-05-2022, 09:23 AM   #2920
67 twins
Location: Herculaneum MO (20 minutes south of St. Louis
Hey at least you stopped before making the 3rd mistake. Which is putting the fitting on the wrong direction. Done that one myself. Sometimes walking away and doing something else is the best thing to do.
67 C10 283 T5 swapped longbed fleetside = wife's daily driver
67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck
67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD
72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck
Can you tell we are fans of longbed fleetsides & 67s
Chris
67 twins is offline   Reply With Quote
Old 06-05-2022, 09:25 AM   #2921
Jiggers72-GMC
We've all done it BASE, no shame in that
Old 06-05-2022, 09:59 PM   #2922
Mortomr
I fabbed up some 3point seatbelt mounts that just clears the gas tank and tucks the ratchet mechanisms snug in behind the bench seat.
Mortomr is offline   Reply With Quote
Old 06-05-2022, 10:52 PM   #2923
Nima
Blue 67
I finally swapped my C20 heavy duty spring to just 1/2 ton coils and replaced the shocks in hope of a little softer ride.
1953 GMC 3/4 ton: current project
1967 C20: 5.3 voretc with T5 conversion, 4 wheel 8 lug disc brake
1972 Nova: my 4 door sport sedan! 5.3 voretc + T5 conversion. drivable project, FUN!!
1979 Camaro Z28: 5.3 vortec conversion with build TH350: drivable project, Fun to drive
1992 Camaro RS convertible (Z28 clone): 5.3 conversion with build T5: on going project
2005 Silverado 2500, 4x4 Duramax, original owner
Nima is offline   Reply With Quote
Old 06-06-2022, 12:49 AM   #2924
FleetsidePaul
R.I.P. E.S.L.L.
FleetsidePaul's Avatar
Springs scare me ever since one of the mechanics at work shot one though the roof of the shop and almost took off his head. The foreman wasn't happy.
Don't ask me how he did it. But he did. He got in a lot of trouble for that one. And of course we all made fun of him.
1971 Custom C/20
1970 CST 20
1970 C/30 Flatbed
1983 C/30 Dually
2015 Corvette Z51 2021 Corvette Z51 1991 Cadillac Hearse 1982 Cadillac Eldorado Biarritz 2000 Porsche Boxster S 2020 Jeep Gladiator 1973 VW Thing 1973 Plymouth Satellite wagon 1963 Baja Bug 1959 Bug Dune Buggy 1970 Baja Bug 1987 Jaguar XJ 350.
R.I.P. El Jay
R.I.P Jessie.
R.I.P Grumpy.
Every day is a gift from God.
FleetsidePaul is offline   Reply With Quote
Old 06-06-2022, 11:46 AM   #2925
72c20customcamper
Worked on the stakeside boards this is why projects take me so long I get carried away . I could have epoxy glued the cracks but no not me . Ended up doing bow ties out of black walnut . Two coats of spar urethane so far .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
