Old 06-05-2022, 10:14 AM   #1
kev2809
low n' slo
kev2809's Avatar
Re: 67 SWB First Build
that color looks good on there!
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 06-05-2022, 01:02 PM   #2
Scurry67
Originally Posted by Kronald_70GMC View Post
Looks awesome! I like your colour choice!
Thanks fellas. I think it’ll look good when it’s all done. I definitely learned a few things that will come in handy when I paint the exterior.
67 SWB First Build
http://67-72chevytrucks.com/vboard/s...d.php?t=777171
Scurry67 is offline   Reply With Quote
Old 09-12-2022, 12:37 AM   #3
Scurry67
Made it up to the shop this weekend. Had enough time to spray the bed. Unfortunately I’ll be redoing the bedsides. There was some orange peel in the clear and after wet sanding, it was evident i didn’t put enough clear down. I’ll more than likely leave the front bed panel alone. It turned out decent. Hoping to get everything painted over the next month or so.
67 SWB First Build
Old 09-18-2022, 11:50 PM   #4
Scurry67
Bedsides sanded down. I decided to leave the roll pan alone as well. I seemed to hit that area with plenty of clear. I’ll plan on reshooting later this week!
67 SWB First Build
Old 09-27-2022, 12:41 AM   #5
Scurry67
Cab and bed in paint, finally! Turned out great for the most part, other than a few runs where i laid the clear on a little too thick. There is also 1 spot where it looks like i missed scuffing in a nook and cranny. I should be able to fix it with little issue. Looking forward to getting the rest done soon!
67 SWB First Build
Old 10-10-2022, 05:25 PM   #6
doug_p
doug_p's Avatar
Beautiful truck man, very nice. One suggestion for your consideration . . . I love the fuel cap, and actually did the exact same thing/location on my 62 LB. However, I would suggest if you can, or while you can - order some more of those pop-up screw in caps. Mine lasted great for about a month and then would no longer work. I had to change mine out to something different. Hopefully your experience is better than mine, but trust me it will be worth the extra cost to have 1 or 2 extras lying around.
Keep up the awesome work!
Doug
doug_p is offline   Reply With Quote
