Mix&Match Burbs?
So,,,
I have 2 Suburbans: 1976 K20 350/THD400 (I believe)/NP203/ Barn Doors 1984 K10 35/THD350/NP208/ Tailgate What I'd LIKE to do is swap the '84 onto the '76 BUT end up with the barn doors on the '84 ANYONE done this? Guidance? Opinions?
1994 C1500 rclb 1988 C1500 rclb 1969 ES5500 B E A S T 1983 C10 'farm truck' 1976 K20 Suburban 1984 K10 Suburban 1981 Jeep CJ5/350 Vortec 1941 Dodge WC18 Ambulance 2000 GMC Bus (parts warehouse) |
Just here to tinker
![]() Join Date: Jun 2008
Re: Mix&Match Burbs?
I would think you’d be able to pull this off. Just swap all the hardware and backing plates for the barn doors to the other body. All the right holes should be there to line everything up. You may have to figure out the courtesy light switches/circuit though as I’m sure it’s in a different spot on the tailgate units.
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
It can be done but the lower sill plate is different between the door styles. it can be swapped but its a bunch of work and welding. I have one I plan on doing that to at some point.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
