Old 03-23-2022, 10:31 PM   #1
psuedopimp
psuedopimp's Avatar
67 gmc tie rod issues
67 gmc rebuilding front end. Started in drivers side and got to the tie rod ends and it is hitting. Any ideas? Hopefully the pics show up
Justin
1970 Blazer in progress
psuedopimp is offline   Reply With Quote
Old 03-23-2022, 10:42 PM   #2
psuedopimp
psuedopimp's Avatar
Re: 67 gmc tie rod issues
Can you install the lower control arm shaft backwards? I’m thinking that’s what I did.
Justin
Old 03-24-2022, 12:51 AM   #3
Bob B.
Your lower control arms do look too far forward.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90.
Bob B. is offline   Reply With Quote
Old 03-24-2022, 06:40 AM   #4
Grumpy old man
Grumpy old man's Avatar
This is how it lined up on my 67 C10 with 2 1/2 " drop spindles and power steering , Using MOOG parts . need some more pictures of what you have .
Old 03-24-2022, 01:35 PM   #5
HO455
HO455's Avatar
It looks as if your centerlink is backwards compared to Grumpy's. It could just be the camera angles. See angles of the red lines below. There are numerous threads on which way to install the centerlink to help you verify if this is the problem.
Good luck.
RIP Bob Parks.
Old 03-24-2022, 03:35 PM   #6
Wrenchbender Ret
It looks like the center link is on wrong. Its also possible the steering gear is not lined up right. The 67 models came out with linkage type power steering & to put the later type gear on you need a conversion bracket kit.
George
Wrenchbender Ret is offline   Reply With Quote
Old 03-24-2022, 04:09 PM   #7
Jason Banks
Jason Banks's Avatar
just went and tried to take a picture of mine from the same angle. I'm guessing your centerlink is in wrong. It tucks up so close to the crossmember when done right, you would think it's wrong.
Jason Banks is offline   Reply With Quote
Old 06-09-2022, 12:15 PM   #8
psuedopimp
psuedopimp's Avatar
Thank you for your replies. The center link may well be the problem. However I will need a picture of what it should look like from the passenger side.
My issue is that it didn’t hit before I took it apart, and now it does and I didn’t mess with the center link. But after taking this think apart 5 times I’m ready to try something else!
Justin
