Old 06-12-2022, 07:05 PM   #1
62bagger
62bagger's Avatar
Proportion valve leaking
I am having a problem with my proportion valve leaking. I am hooking up the brakes for the first time and I cannot get this line to stop leaking. has anyone else had this issue. I have rebuilt this line 3 times with no luck.
Thanks.
62bagger is offline   Reply With Quote
Old 06-12-2022, 11:37 PM   #2
MT65
Re: Proportion valve leaking
I would think there are only three reasons for it to leak…not tight….bad flare…bad seat in the valve…my .02
MT65 is offline   Reply With Quote
Old 06-13-2022, 09:11 AM   #3
geezer#99
geezer#99's Avatar
You need to ‘mate’ the flare with the seat.
Make a new line and this time just snug it up, not tight yet. Loosen it and then tighten again. Only this time go a little tighter. Repeat that process going tighter and tighter about 6 times.
Old 06-13-2022, 09:56 AM   #4
MikeN
MikeN's Avatar
I have had great luck using copper washers to seal inverted flare fittings. I keep them in my tool box in several sizes to use whenever I have a flare fitting that won't seal. They work on fuel lines, brake lines, transmission cooling lines, whatever. You can order them online from Grainger, see link. They are made specifically for inverted flare fittings.
https://www.grainger.com/product/5WR...E&gclsrc=aw.ds
MikeN is offline   Reply With Quote
Old 06-13-2022, 11:08 AM   #5
The Rocknrod
Moderator
The Rocknrod's Avatar
Great advice!
Old 06-13-2022, 01:46 PM   #6
62bagger
62bagger's Avatar
Thanks for the advise. I used geezer#99's method and it worked. As usual, great information from this site. Thanks geezer#99 and everyone for the responding to my question.
