#76 |
Re: subframe question
Sorry, thought you said 81 up.
#77 |
#78 |
I have a 57 one ton and I installed 73 3/4 ton frame on my truck and it could'nt have worked out better, I cut a c shape right behind where shocks were mounted. I then removed the rotors and calipers, installed 1988 one ton rotors, put the calipers back on and a proportioning valve and a dual chamber m cylinder in the stock location with a booster and it rides, handles, steers, and stops like a 73 to 85 square body. make sure to right down any V I N or serial number you come across, most frames are numbered on the front. and make sure (most important) that you keep the wheel base the same.
#79 |
Included some pics if it helps. TonyMann.
#80 |
can get a 91 1 ton dually frame but not sure on making it work.
also can get a mid 90's 3500 hd. it has 19.5 wheels and 454ci with 4l80e Those years have a lot more curves in the frame. |
#81 |
Got my hands on a perfect 1980 long bed 3/4 ton frame. Looks like I will do the complete swap instead of the graft after all.
#82 |
Nice. Post up so.e pics when you get rolling in it.
#83 |
8 inches removed from wheelbase
#84 |
Nice fitment. Should weld up nice.
#85 |
plates bolted into place and ready to weld.
I know the plates are overkill but I like to over engineer everything. |
#86 |
frame is nice and straight
#87 |
cab mounts installed
#88 |
engine and tranny is in
#89 |
1st suburban tank bracket installed
#90 |
good forward progress. keep plugging away and soon it will be together.
