Old 06-13-2022, 10:59 AM   #1
Classics Fan
1971-72 Differences
Can anyone tell me the differences that distinguish a 1971 Jimmy from a 1972? Trim, mechanical, structural, etc.? TIA!
Classics Fan is offline   Reply With Quote
Old 06-13-2022, 11:55 AM   #2
truckster
truckster's Avatar
Re: 1971-72 Differences
Easiest way for me is the rear view mirror. On the 71, it's screwed to the headliner. On the 72 it's glued to the windshield.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
1972 K/5 Blazer CST 4WD
1963 Corvair Monza Spyder Turbo convertible
1995 Camaro Z/28
truckster is online now   Reply With Quote
Old 06-13-2022, 12:49 PM   #3
richard2717
Equal opportunity joke ofender
richard2717's Avatar
72 frame in the rear comes out far enough for bumper to bolt to. 71 requires brackets.
72 has metal ferrules and screws under the wing window on the door 71 is plastic
72 has plastic molded door panels 71 down has metal door panels
Members I have met.
Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb
https://paypal.me/6772GMtruckparts
Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type.
richard2717 is offline   Reply With Quote
Old 06-13-2022, 08:44 PM   #4
CK5
CK5's Avatar
Front disc brakes new for 72
Rear seat went to only 2 rear legs in 72
I believe single wall hard top came out mid year 72
CK5.com
1972 Blazer Build
CK5 is offline   Reply With Quote
Old 06-13-2022, 09:58 PM   #5
Classics Fan
I believe front discs came out in 71 for Jimmy. Mine has them and I read somewhere that’s correct.
Old 06-13-2022, 09:59 PM   #6
Orange71shorty
Front disc brakes came standard in 1971
Orange71shorty is offline   Reply With Quote
Old 06-13-2022, 10:04 PM   #7
Classics Fan
My Jimmy has both the plastic ferrules and plastic molded door panels. One thing I was trying to figure out is, were the entire doors replaced or only the panels? The more I dig he more I’m convinced it was only the panels and not the doors. Thanks!
Old 06-14-2022, 12:13 AM   #8
CK5
CK5's Avatar
Didn't realize Jimmy got disc brakes a year earlier than the Blazer.
CK5.com
1972 Blazer Build
Old 06-14-2022, 07:50 AM   #9
68panelman
68panelman's Avatar
All C and K series truck had disc brakes standard for the 1971 model year.
68panelman is offline   Reply With Quote
Old 06-14-2022, 09:52 AM   #10
1rippen6
A 71 door will have nuts along the bottom for the door panel, the door panel attaches with 4 screws along the bottom. 72 only have holes, the panel attaches with the Christmas tree push pins and 1 screw mid way up the back side. Door relay and window cranks are longer for a 72, to accommodate the thicker door panel. If you are trying to determine whether is a 71 or 72, the easiest way is look at the tail pan under the tailgate. 72's have notches above each frame rail, guess for clearance since they extend out to the bumper, 69-71 doesn't have this.
1rippen6 is offline   Reply With Quote
Old 06-14-2022, 11:19 AM   #11
Blazerowner
Blazerowner's Avatar
Yes the single wall top was a mid year change in 72. I wasn’t aware of the rear seat only having two legs in 72.
Kirk
72 Blazer CST 4wd highlander
Blazerowner is offline   Reply With Quote
Old 06-14-2022, 11:49 AM   #12
1rippen6
I believe DeadheadNM has a thread started trying to figure out the exact date for the single wall top, if I remember correctly, they were only installed at 1 assembly plant. The thread will have the info but I believe it's associated with the under dash speaker also.
Old 06-15-2022, 10:27 AM   #13
Classics Fan
Size:  39.3 KBBesides wanting to generally know what to look for to distinguish between the two years, I had a more specific reason. My Jimmy has what appears to be 1971 doors with 1972 panels. That seems odd given (if I understand correctly) the window regulator would also need to be changed to update the panels to 1972. I had entertained the thought the doors had been replaced or even the whole body had been replaced (the VIN plate was secured by non-rosette rivets when I purchased it). It seems now everything is likely original except the panels.
Thanks for everyone’s input!
PS: how the heck do you rotate uploaded pictures so they aren’t sideways?!
Old 06-15-2022, 10:44 AM   #14
1rippen6
Here to you, get a picture of the latch area, a blazer door should have a reinforcement plate from factory.
Old 06-15-2022, 10:54 AM   #15
Classics Fan
I’ll post a pic of the latch area. How were you able to rotate this one?
Old 06-15-2022, 11:03 AM   #16
1rippen6
Saved it to my computer, rotated it in paint and reposted. You maybe able to rotate them on your phone but haven't tried.
Old 06-15-2022, 11:20 AM   #17
Classics Fan
Here are both the door and body latches. Look correct?
For the life of me I can’t get my pics to load correctly!
Old 06-15-2022, 11:30 AM   #18
1rippen6
Yes, looks correct
Old 06-15-2022, 11:46 AM   #19
richard2717
According to the vent window screw it appears to be a 70-71 door with a 72 panel made to fit. 72 should look like this
Members I have met.
Old 06-15-2022, 11:51 AM   #20
dagnabbitt
dagnabbitt's Avatar
I am not an expert and maybe I am misunderstanding, but it appears to me that those are 72 doors with 72 panels.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 06-15-2022, 02:35 PM   #21
richard2717
70- 71 has this style which is what it appears to me to be in the picture op posted. It is hard to see in his pic but appears to be black. if it is actually like the pic I posted in #19 it is a 72 door only.
Members I have met.
Old 06-15-2022, 04:48 PM   #22
Classics Fan
Mine has plastic ferrules (the bezel around the reinforcement screw under the vent window. I guess the only way to tell for sure is to pull the door panel and see if it has the nuts for a 71 panel as these could have been brought over from 71 doors if they had been changed. Am I missing anything?
Old 06-16-2022, 05:09 PM   #23
john deere
Since your VIN plate has been tampered with I would see if the VIN stamped in the frame matches it. It is located on the drivers side top of the frame near the power steering pump. Also the blue tag on the drivers door should give a build date on the very top, right side if it is still readable. Does your title and everything else mentioned above indicate it is a 71?
john deere is offline   Reply With Quote
Old 06-17-2022, 10:12 AM   #24
Classics Fan
My curiosity about this rig started soon after I bought it. This thread I started then provides more detail.
http://67-72chevytrucks.com/vboard/s...d.php?t=759924
Both the SPID and the blue door tag shown signs of “possible” tampering (note the edges) but the frame VIN matches. The rest of the truck looks and feels genuine and untampered. Just trying to be a detective I guess.
