#651 |
60-66 Nut
Re: Lost My 65
I agree that, that is a good and wise plan.
That frame has a strange looking trans crossmember. It isn't like anything I have seen in a truck before.
#652 |
Rollin' Old Skool
Re: Lost My 65
Glad you're getting to enjoy the truck. Like the others have said, the frame swap sounds like a nice idea as well.
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
#653 |
Re: Lost My 65
Really enjoyed reading through this thread! I am "recreating" my dad's 62 c10 from high school. He sold it to a junker when he was younger in his first marriage. He regrets it all the time. I would love to find it....but he thinks it is long gone.
Also, dig the blue/black patina.
Builds: 1962 C10 Recreating Dad's High School Truck 1981 C10 |
#654 |
But Found Her 25yrs Later!
Re: Lost My 65
Thanks guys.
Yes, Captain. I was going to ask you about that Trans member. I used the Google search this site has and searched images but didn't find one that looked like this one. If it gives me any issues, I have one from a 67-72 I can use.
#655 |
Re: Lost My 65
This time of the year is the most beautiful.
Everything is lush and green. Although the blackberries just love it too. :-( I guess I need to get out there with a machete. ![]()
#656 |
Re: Lost My 65
#657 |
Re: Lost My 65
Before I went to power steering, I had a lot of play in my old manual steering box. So I chalked up my steering instability to the old worn steering box. For my upgrade to power steering, I went with redhead because wanted to have nice tight steering with no play. After I upgraded to power steering, I noticed a huge improvement in steering stability, but it still didn't have what I was wanting. So I went through all the linkage and arm connections again to make sure there weren't any warn components.
Well, I went to searching and reading the forums for some more learnin. I learned about caster, camber and toe - enough to give me the confidence to do my own alignment. Camber and Toe weren't the issue. It was caster. My truck had almost zero caster. I've learned that more positive caster will give more straight driving stability. So, I started with taking two shims off the back posts on the upper arms. A definite improvement. Going to give a it little more caster
#658 |
Re: Lost My 65
You can move your lower a-arms forward up to 3/4" of an inch for better caster, and highway stability. There are several threads on here detailing how. Enjoy watching your continuing saga.
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
#659 | |
Re: Lost My 65
Thanks,
Rocknrod posted a link to that thread in another thread. Quote:
#660 |
Re: Lost My 65
Because the ol' fella who had my 65, bought the rims for the truck as part of his vision, I pretty much decided to keep them since getting her back. That way as I send him progress pics, he can see I still have them. It doesn't hurt that I also happen to like them.
They are 10" wide with 295/50-R15 all the way around. When I mocked up the Drop Spindles with Discs, I noticed it was going to move my wheels out almost 1/2 per side. So I've been keeping my eyes out for the same wheel at 8" wide. I'll do the 8"s in the front and the 10"s in the rear. Set them up so I can keep this look. ![]() . After watching the ads for over a year, I finally found the same wheels in 8". They came with 31x10.5-R15's so I thought I'd mount them up just for kicks. Not my taste. ![]() .
#661 | |
Re: Lost My 65
#662 |
64-66 CHEVY JUNKIE
Re: Lost My 65
This was a Excellent read Great Story from beginning to end, I spent all Day Reading it.. When you Posted the last set of Google Earth pics from the different angles, I know it was your truck I could see a dot on the Passenger rear side (65 fleetside tail light) Anyways You Got Running and Looking Good... Congrats on Finding Your 65... Chris....
1966 C-10 Fleetside LWB, 350 Lt1 4l60-E 2008 Silverado Crew Cab, 4.8 4l60-E 1998 GMC Yukon 4x4 L-31 Vortec, 4l60-E 2017 GMC Serra 4x4 5.3 Vortec, 4l60-E ![]() ![]() |
#663 | |
Re: Lost My 65
#664 |
Re: Lost My 65
I bought my 65 when she was around 18.
It's hard to believe she's around 55 years old now.
#665 |
Re: Lost My 65
One of my fitech injectors quit working.
I was struggling to figure out which new ones I needed to order. I found out watching this video: https://youtu.be/TDx7MPVDzAY
#666 |
The 60-66 GMC/Pontiac guy....
Re: Lost My 65
I remember before you found her.
![]() Building Genuine Pontiac Firepowered cars and trucks for several decades. ![]() Why Pontiac?? That's just me daring to be different. ![]() Projects.. 63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction. 440CID 2X4 Pontiac ![]() |
#667 |
Re: Lost My 65
Yep, and it was ones like you that motivated me to keep looking.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 Last edited by LostMy65; 05-21-2021 at 11:03 AM. |
#668 |
Re: Lost My 65
If any of you have been following this thread and my 66 thread, you'll know that I change directions a lot.
I found my 65 I had when I was a teenager and bought her back about 10 years ago now and I still haven't got all the upgrades I wanted to do to her done. So, my latest direction is to move my 65 cab and front clip over to the 66 frame with the long fleetside bed. The 66 already has power steering, power disc brakes, a 14 bolt, and a low mileage 350. The whole downside to the 66 was how bad of shape the cab was in. That is my goal for this weekend. . So far I've made it to setting my 65 cab onto the 66 frame. Going to bolt it down and start hooking things back up tomorrow.
#669 |
Re: Lost My 65
This will be close to the look I'll be shooting for.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 Last edited by LostMy65; 06-20-2022 at 12:27 AM. |
#670 |
![]() ![]() Join Date: Jul 2002
Re: Lost My 65
Really liked your short stepside version, but since I am a long bed owner now, I can definitely see the goodness coming from you going this way.
#671 | |
Re: Lost My 65
Oh yes, the stepside is definately a great look - even my wife would have preferred me to keep the lowered hotrod wide wheels stepside, and I can always go back to it - I'm not getting rid of it. But I want to go long fleet for a time.
#672 |
Re: Lost My 65
All I got left to do is hook up the brakes and I can take it for a spin.
Again, I'm doing this because the 66 has all the upgrades. Now I'll use the frame I posted here a few pages up and do all the upgrades to it while I keep my 65 rolling on the 66 frame. I'm going to sell my 62 Shortbed frame or make a trailer out of it.
#673 |
Re: Lost My 65
Yes, it's not as cool looking, but it'll do for awhile.
#674 |
![]() ![]() ![]() Join Date: Jan 2018
Re: Lost My 65
I think it looks great! You're still going to be able to keep it on the road, and those upgrades already on that frame is a big plus. Long live long beds
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
#675 |
Re: Lost My 65
Thanks for the encouragement, that helps.
