BlahBlahBlah
Bucket seat question
I have a pair of buckets that were in a Blazer. Can I take off the passenger side seat brackets and bolt in the same place the truck style seat bracket? Dunno why they would have made the mounting points different but figured Id ask before I sent the Blazer brackets down the road.
Roadtrip!
![]() Join Date: Feb 2003
Re: Bucket seat question
Should be able to bolt them on if the seats are the sport style. Not sure if the utility seat was the same. I can relieve you of your blazer brackets if they need a home...
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
BlahBlahBlah
Yeah sport buckets, thanks for the help!
The drivers side Blazer brackets are longer than truck brackets.
I have buckets out of a 70 K-5 in my C-10. What I did was, remove the brackets from both seats, and mount the brackets off two bench seats. I know its no Factory Correct, but its my truck, and I like how they fit. Its been awhile, but if I remember right, I had to fabricate mounting points so they would attach, and then also make reenforcing pads in the floor. Since the bench seat brackets only have the adjuster on the Left side, the passenger bucket will be on the inside. (The lever has to be shortened to clear the factory center console) One thing I want to do, is fabricate an actuator lever system, so that I can adjust the passenger seat from the lower front near the bracket leg. Ill try to remember to take pictures, when I get it built and it works. ![]() |
![]() Join Date: Mar 2015
"I have a pair of buckets that were in a Blazer. Can I take off the passenger side seat brackets and bolt in the same place the truck style seat bracket?".
Short answer is no with caveats. Yes, the Blazer seats can be installed but they are different than the truck seats because they fold forward. The passenger truck seat, from the factory, is not adjustable. If you were using the truck seat on the passenger side I believe you can use one of the original bolt holes that retained the bench seat. I Sounds like the Blazer seat may use different bolt pattern. The other three holes need to be re-drilled. The floors for the bucket seats was different than the bench seat floor. The bench floor is missing the reinforcement under the floor for the seats. This is important if you ever get in an accident. I would install them but expect it to be a PITA to get them installed in the correct location. A board member sells the lower floor reinforcements you will require if you duplicate the factory set up. Cheers Last edited by Accelo; 06-20-2022 at 10:35 AM. |
BlahBlahBlah
Thanks for the extra info. I do have a factory bucket seat truck that has a bench in it now. I do have a set of Blazer buckets. The passenger bucket flips forward, I don't need that feature. I'm fine with the solidly mounted (no forward or backward adjustment) truck style passenger seat mounting bracket. There is a member here that sells them. My basic question was can I remove the entire Blazer bracket from the seat side and install the truck style mounts bolted in to the same holes the blazer seat tracks were bolted on the seat part, not the floor part.
Drivers side Blazer bucket was brought up. From what I have read it should bolt right in because I have an original bucket seat cab. I feel all the sport buckets are the exact same truck or Blazer, except for the mounting mechanism on the passenger side. One style for truck, one style for Blazer.
That is correct. You can just use the brackets for the truck with Blazer buckets
