#176 |
Re: 2wd swap
I like it.
#177 |
At the body shop.
Re: 2wd swap
The gov lock did its normal thing.
This is the 2nd time the 12 bolt gave up. Couldn't believe the amount of hate the 9in replacement got. Didn't know the gm fan boys where that way.
" That didnt make it any newer " " Dont antique the equipment " |
#178 |
Re: 2wd swap
Well..... The GOV lock set-ups are known weak links so there's that. I'm fine w/the 9" or 8.8 options.
#179 |
At the body shop.
Re: 2wd swap
He knew the issues with the gov bomb.
Also don't suppose the donuts spun had anything to do with it. Lol
#180 |
Re: 2wd swap
No way...
#181 |
At the body shop.
Re: 2wd swap
Kid surprises me again.
Cal trac housing bracket won't cooperate with the dual shock brackets. Because pre runner stuff. So he downloaded fusion 360 Tuesday. Sends me this Wednesday
#182 |
Re: 2wd swap
Man.... How cool would it have been to have tools like this that one-time I was a young-gun?
#183 |
At the body shop.
Re: 2wd swap
Would have saved hundreds of cut off wheels
#184 |
Re: 2wd swap
I'm sure we saved them..... In our lungs
#185 |
At the body shop.
Re: 2wd swap
I was thinking about my ears, but yeah that too.
#186 |
At the body shop.
Re: 2wd swap
After a complete failure with the local guy, sendcutsend.com blew us away.
Kid left a .010 tolerance and it fit together so well that it needed a love tap to take apart for the final fit up
" That didnt make it any newer " " Dont antique the equipment " Last edited by KQQL IT; 06-13-2022 at 01:15 AM. |
#187 |
At the body shop.
Re: 2wd swap
Brother's on vacation.
Back on the K5 my son's got the fusion360 working pretty well I think. Since we sectioned the crossmember 1.5 inches then raised the upper pivot the same trying negate some bumpsteer and got only a 2° camber change thru the usable travel. He drew us up a new upper pivot that's 1.75 taller than stock and created an access hole for the airbag fittings. May also ad in a coil over mount into it.
" That didnt make it any newer " " Dont antique the equipment " Last edited by KQQL IT; 06-20-2022 at 10:38 PM. |
#188 |
At the body shop.
Re: 2wd swap
Final render
#189 |
At the body shop.
Re: 2wd swap
1st mock up
#190 |
At the body shop.
Re: 2wd swap
New parts came.
#191 |
At the body shop.
Re: 2wd swap
Welding it out.
#192 |
At the body shop.
Re: 2wd swap
Sperical washer.
Sure why not.
#193 |
Re: 2wd swap
What's the purpose (need?) for the spherical washers?
#194 |
At the body shop.
Re: 2wd swap
The choppin block arms have a tight(er) tolerance on the stud.
And with any caster in the shim stack it bends the stud overvwhen flange nut is tight. And looks better than the factory stuff.
" That didnt make it any newer " " Dont antique the equipment " Last edited by KQQL IT; 07-09-2022 at 09:02 PM. |
#195 |
Re: 2wd swap
Makes sense. Where did you source them for reference?
#196 |
At the body shop.
Re: 2wd swap
Jungle site.
Morton - SP-2 Low Carbon Steel Spherical Washer Sets, Equalizing Washers, Inch Size, 1/2" Bolt Size https://a.co/d/fsst9WR
#197 |
At the body shop.
Re: 2wd swap
Brother's 9 inch back from powder.
Hopefully get it under it today.
#198 |
At the body shop.
Re: 2wd swap
Got hosed, axles are wrong.
Bar brackets came out neat
#199 |
At the body shop.
Re: 2wd swap
.250 spacer
And the calipers clear
#200 |
At the body shop.
Re: 2wd swap
Success
" That didnt make it any newer " " Dont antique the equipment " Last edited by KQQL IT; 07-25-2022 at 10:48 PM. |
