Old 06-06-2022, 08:23 AM   #126
Jiggers72-GMC
Jiggers72-GMC's Avatar
Re: Bringing my Grandfather's 1972 Longbed Stepside C10 back to life
Well done, I almost ordered a kit from LMC, I'm getting my exhaust done locally next week.
Gerry, North Bay Ontario
1971 Chevy K10 short stepper, 518 med green & white
1972 GMC C1500 long box, dark Brown, owned since 1977
1969 GMC C2500 manual
Jiggers72-GMC is offline   Reply With Quote
Old 06-12-2022, 10:55 PM   #127
bwl101
bwl101's Avatar
Put new front wheel bearings, front rotors and pads. Much easier to stop and much quieter! Also was able to finish up the exhaust install as I got the muffler delivered Friday that was missing in the kit's box. Has a good sound and it is also pretty quiet which I am happy with. Only difficult part of finishing the install was there was an exhaust leak where the pipe meets up to the exhaust manifold. Had to straighten out the angle of the pipe as it straightens out to run under the truck. All good now!
'72 C10 Long Bed Stepside
Putting my Grandfather's truck back on the road:
http://www.67-72chevytrucks.com/vboa...d.php?t=829659
bwl101 is offline   Reply With Quote
Old 06-13-2022, 08:07 AM   #128
Jiggers72-GMC
Well done on the exhaust,
if you can bleed the brakes to get new fluid in there that would be good,
all that grease on the upper arm kept it from rusting huh
Old 06-13-2022, 12:05 PM   #129
bwl101
bwl101's Avatar
LOL yea! Got the brakes to bleed correctly. On the side pictured, apparently at some point, the seal on the inside bearing busted that's why that area is so greased up. I wish I had taken a picture after cleaning everything up with the new rotors and bearings installed! Looks much better now and stops much easier and quieter!
Old 06-21-2022, 11:37 PM   #130
bwl101
bwl101's Avatar
Dropping it off at the trans shop tomorrow for them to replace all the leaky seals, replace carrier bearing and a rear diff service!
Old 06-22-2022, 07:19 AM   #131
Jiggers72-GMC
It will be nice to get that done, I hope they're price is fair.
Old 06-23-2022, 12:45 AM   #132
bwl101
bwl101's Avatar
We shall see lol, so far what they've done:
Shift shaft seal
Rear seal
Carrier Bearing
All 3 U Joints
Rear Diff Fluid Service
I'll get the final list tomorrow when I pick it up.
Old 06-23-2022, 08:02 AM   #133
Jiggers72-GMC
I guess they'll replace the trans filter while they have the pan off ....... and fresh trans fluid too.
Old 06-23-2022, 08:29 AM   #134
bwl101
bwl101's Avatar
I already replaced the filter and pan gasket before taking it to them, but I'm sure they'll have to top the fluid off even though by now it should have had all the old fluid cycled out.
Old 06-23-2022, 08:31 AM   #135
Jiggers72-GMC
That's right, sounds good
Old 06-24-2022, 12:21 AM   #136
bwl101
bwl101's Avatar
Shift shaft seal
Rear seal
Carrier Bearing
All 3 U Joints
For this work it was $257. I got it home and it was leaking still. Took it back and with everything else sealed up it made its way out of the speedometer cable where it attaches to the transmission. They will swap that O ring or whatever it is that keeps that sealed. Hopefully that'll be it and it will be leak free after that. I felt that was a fair price for all that work!
Old 06-24-2022, 07:24 AM   #137
kev2809
low n' slo
kev2809's Avatar
what a deal! and now you know how fresh everything back there is
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 06-24-2022, 07:41 AM   #138
Jiggers72-GMC
Yes, what Kev said, the speedo seals are an easy fix .......
Old 06-25-2022, 10:55 PM   #139
bwl101
bwl101's Avatar
Speedo seal is good now, but the shift shaft seal started leaking again today so I'll have to take it back in on Monday.
Old 06-25-2022, 11:07 PM   #140
bwl101
bwl101's Avatar
I bought one of the DA short throws from Harbor Freight to help me get the grime off the paint that wouldn't power wash off. Some black stuff on the hood would not budge with a mild abrasive and pad. I didn't want to mess the paint up so I looked for other ways to help "clay" the paint without actually having to clay bar everything as that would take forever! Well I came across the suggestion of using comet to wash the truck. Man what a difference! Cleaned a ton of old oxidized paint off and got all of the hard to remove black stuff off without too much effort. I used the bug removal sponges with the white netting on them with comet and water. As you can see in the pictures what a huge difference. The front bumper looks way better too! Tomorrow I plan on washing the rest of the truck with comet, then I will apply the Meguires #7 to rehydrate the paint while maintaining the patina look! I only had time to do the front bumper, hood, cowl and both front fenders today. In the last pic it's pretty obvious the difference between the hood and front fenders compared to the door that hasn't been washed with the comet yet.
Old 06-26-2022, 01:53 AM   #141
68Gold/white
I’d drive it!!
68Gold/white is offline   Reply With Quote
Old 06-26-2022, 02:00 AM   #142
68bowtie
68bowtie's Avatar
Wow what a difference. Looks great!!
Old 06-26-2022, 07:04 AM   #143
Great job!
Old 06-26-2022, 10:17 PM   #144
bwl101
bwl101's Avatar
Finished cleaning the truck with comet and then used the harbor freight DA to put Meguires #7 all over. Worked really nicely to deepen the color!
Old 06-27-2022, 08:12 AM   #145
Jiggers72-GMC
The truck really turned out nice, your Grandfather would be proud.
Old 07-04-2022, 12:36 AM   #146
bwl101
bwl101's Avatar
Getting the Oak bed wood ready to put in this week!
Old 07-04-2022, 09:37 AM   #147
Jiggers72-GMC
The wood looks great, nice choice in stain.
Old 07-05-2022, 05:37 PM   #148
Hawkynz
Junior Member
Hawkynz's Avatar
Im amazed at how good that paint looks.
Hawkynz is offline   Reply With Quote
Old 07-05-2022, 11:54 PM   #149
bwl101
bwl101's Avatar
Got pretty much finished installing the new bed wood. It is very tedious hand tightening 92 bolt/nut combos lol! Have 6 more to go as they are in very tough spots to get and will have to think it through getting to them. I am very happy with how it turned out!
Old 07-06-2022, 06:42 AM   #150
kev2809
low n' slo
kev2809's Avatar
very nice!
-_--_--_ _________
