![]() Join Date: Mar 2016
Why Do the Squares Wiggle in the mid 60s mph?
Everybody I talk to observes the same thing. Is it just frame resonance?
Just here to tinker
Re: Why Do the Squares Wiggle in the mid 60s mph?
I’ve owned 8 different squares and I’ve never experienced this. Can you explain further?
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/showthread.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 73 Chevy C20(Daily)http://67-72chevytrucks.com/vboard/s...d.php?t=852767 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(sold) |
I've never experienced this wiggle. I've had 1/2t and 1t 2wds as well as K/5, 3/4t and 1t 4wds including Suburban. What do you and the others own that wiggles?
![]() Join Date: Mar 2003
Tighten bolts and get a good front end alignment?
![]() Join Date: May 2015
Never heard of it either
![]() Join Date: Dec 2009
I have owned several.
I have not experienced this.
________________________________________________________________________________________ ____________________________________________ The early bird gets the worm, But the second mouse gets the cheese 85 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
![]() Join Date: Jan 2003
My 1978 Longbed is smooth. Never had this happen.
1969 307, t3501950 Chevy Wagon 1978 Big 10 1967 C10, 250,3-OTT |
Looking at your profile pic what size tires are you running are they over sized 4x4 off road tires. If they are that may be because your running to much side wall, that may be where some of it coming from. The bigger the side wall & the faster you go the more the side wall will grow at speeds and give you some wiggle.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bedWas a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
It's nothing like death wobble. It's just certain speeds that have harmonic vibrations. Talking to quite a few folks, they experience it at between 63-67 mph. You couldn't align, balance, check or brand new anything more on this rig.
It's almost impossible to get a perfect tire balance; even on my Cadillacs. My 76 GMC has a tire vibration between 57-60 mph. It smooths out before and after those speeds.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
My 75 C10 does it on occasion. The vibration has survived several sets of tires, a new set of rear bearings, new u-joints, a new exhaust system, and a major fix-up of the front end.
When mine does it, it cycles between nothing and a very noticeable vibration over a couple of seconds. Tends to be at higher speeds, above 65. Guessing it is a combo of exhaust drone interacting with tire speeds and drive line vibrations. |
47-52 MPH for me. More of a up and down wobble.
Yes. This is the experience. It's smooth at all other speeds. It's done it with multiple sets of tires. Even though I have a well balanced CV driveshaft with a properly shimmed pinion angle, I still feel like some of its there, but the rest I suspect is resonance in the frame.
Mine doesn't.
Rock solid as fast as you want to go. As a former full vehicle development engineer, driveline development engineer and brake development enginer - I've never noticed it on any of the thousands (?) of squares I've driven. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
#15 |
And to clarify, it feels like a driveshaft or wheel balance deal.
#16 |
We did have a few "inherent" wobbles that got built in, but more like during the GMT400 and GMT800 days.
The longer trucks could get into a frame "beaming" mode but that was usually vertical (up/down, rather than crosscar). I also recall a particular extended cab configuration that would wobble right off the line. Just two or three kicks, as a result of the 2 piece driveline configuration, and then clear up. That was one you weren't going to fix without some "invention". K
#17 |
Both my squares have a slight vibration around the 65mph mark, although I've always chalked it up to never having had an alignment or balance done on either.
#18 |
Keith you explained what I experienced with my 77 Suburban . Truck would go up and down we used to call it porpoising. My 87 burban only did it when towing but my 77 would do it regularly.
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. Last edited by 72c20customcamper; 06-28-2022 at 08:58 AM. |
#19 |
Keith: You seem comfortable in this space. What would you look at? I've had the wheel tire setup balanced on a fancy machine. Driveshafts built by Tom Woods. No difference before or after.
#20 |
all of the m1008 that i have owned and my 79 k30 will sway a little when acceleration you can feel it go right and let off the pedal a little and it will go back straight i think its caused by the torque from running the 4,56 gears
#21 |
What Hump?
& rplace lea spring bushings and ball joints and any other warn out suspension parts
Lil red 86 c-10 99 Sub 78 Camper Special w/ 454 |
#22 |
One thing I forgot to mention is that these frames be it 2 or 4x had a tendency to crack around the steering box mount. Check the bolts for tight and look carefully for cracks
#23 | |
I think you just Nailed this Issue. Op needs to check the frame for cracks and add one of these.
| Bookmarks |
