Rear air deflector
Got a rear air deflector from a '79 Suburban. Got it fairly cleaned up. It had a wood-grain decal baked onto it from all those years in the sun. It fits pretty well. Gonna have to tweak it just a little. Doesn't look too bad just sitting on top....
![]() Join Date: Dec 2009
Re: Rear air deflector
That looks good
![]() Flip for ya.
I still can't figure out how to flip 'em...thanks.
![]() Join Date: May 2002
Does that have 1 or 2 mounting points? Can you show how you mounted it, both inside and outside? I think at some point someone added one on mine, and has filled over the holes with bondo
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD ![]() Using your turn signal is not "giving information to the enemy" 67-72 FAQ |
It's got 3 mounting brackets. Will have to drill 6 holes, and it uses inserts that compress like a rivet for the screws to go into. Won't be visible from the inside.
Finally got it permanently mounted! I think it looks like it came that way!
Those Rev-Nuts work great.
Flip for ya. Great job ![]()
I took a torch to aluminum brackets to lessen the angle. Worked like a champ.
1955 Chevy, 2 dr post, my first car 1969 Chevy C20 Suburban, 6.0 LS w/4L80 2001 Silverado Z71, 5.3 extended cab |
Poor computer skills. Haven't figured out how to post pics.
