Old 06-29-2022, 09:33 PM   #1
65truckowner
65truckowner's Avatar
1982 Chevy truck wheels
I bought a all stock 1982 chevy truck that was just parked for several years. My question is it has the factory ralley wheels. I have a nice set of aluminum wheels that would look good on it. My plan is to get it running then sell it. Should I keep the stock wheels on it or put the aluminum wheels on it.
65truckowner is offline   Reply With Quote
Old 06-30-2022, 04:39 PM   #2
Mathew21
Mathew21's Avatar
Re: 1982 Chevy truck wheels
I prefer the rally wheels.
It only has original paint once
Mathew21 is offline   Reply With Quote
Old 06-30-2022, 04:52 PM   #3
Keith Seymore
Keith Seymore's Avatar
You are the only person that can answer that.
But - if you go with aluminum- there will be folks lined up to take those rally's off your hands.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 06-30-2022, 06:35 PM   #4
65truckowner
Just wondering what would make the truck sell better stock or aftermarket
Old 07-01-2022, 08:04 AM   #5
kipps
Advertise the truck with the choice of either wheel set. Once the truck sells, then sell the remaining wheel set.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome!
kipps is offline   Reply With Quote
Old 07-02-2022, 09:03 PM   #6
65truckowner
Tried to start the truck today and it cranked just a little then will only click. Cant turn the engine over now. Is a 305 worth rebuilding?
Old 07-03-2022, 12:20 AM   #7
Gotenntitans
Gotenntitans's Avatar
Nothing wrong with a 305. If it turned over and now it only clicks, sounds like the battery to me.
GoTennTitans
1987 GMC Sierra
1990 GMC Sierra (stolen)
2003 Chevy Silverado
Gotenntitans is offline   Reply With Quote
Old 07-03-2022, 08:02 AM   #8
65truckowner
brand new battery and I cant turn the engine with a brake over bar
Old 07-03-2022, 08:27 AM   #9
kipps
How long has it been since the engine was last run? Is there any possibility that a cylinder got flooded with fuel and hydrolocked? Pull all the spark plugs, and try barring it over again.
Old 07-03-2022, 03:14 PM   #10
Corts60
Just here to tinker
Corts60's Avatar
Yeah it sounds hydro-locked. Remove spark plugs and try again as mentioned.
Old 07-03-2022, 10:16 PM   #11
65truckowner
No fuel going to the carb. I was just trying to see if the engine would turn over. It has been sitting for 10 plus years. I pored some trans fluid down the intake and am going to let it sit for a few days and try it again.
