Old 06-14-2022, 10:13 AM   #151
docrock
docrock's Avatar
Re: 1956 3100 build
Looking Great
1954 GMC on 93 Silverado chassis http://67-72chevytrucks.com/vboard/s...d.php?t=408344
1942 Chevy 1/2 ton Pickup http://67-72chevytrucks.com/vboard/s...d.php?t=429494
R.I.P. TOM SEFFRON 68 FOUR DOOR http://67-72chevytrucks.com/vboard/s...d.php?t=495438
1942 Chevy that ate my brain 70 Chassis https://67-72chevytrucks.com/vboard/...d.php?t=835250
docrock is offline   Reply With Quote
Old 06-14-2022, 04:14 PM   #152
56 3100
56 3100's Avatar
Re: 1956 3100 build
thanks Doc. i get to bring it home tomorrow. cant wait.
56 3100 is offline   Reply With Quote
Old 06-17-2022, 07:54 AM   #153
6DoF
6DoF's Avatar
Re: 1956 3100 build
holy crap, i always kind of felt like i was missing stuff in this thread ... then page 4 when ppl started talking about color and i had no pictures sealed it. never could get pictures to load and finally loaded it on another computer. i did miss a lot!
great work and that color is siiiiccck.
(in post 118, that DeWALT drill ... i designed a lot of that drill! i love seeing them out in the wild.)
6DoF is online now   Reply With Quote
Old 06-17-2022, 11:36 PM   #154
mr.mud1
mr.mud1's Avatar
Re: 1956 3100 build
very nice truck you're building,great work.
mr.mud1 is offline   Reply With Quote
Old 06-21-2022, 09:22 AM   #155
my56chevytruck
my56chevytruck's Avatar
Re: 1956 3100 build
By the way, I haven't read anywhere what your body color is, so can you tell us now? Are you sticking with a carb?
RUBBER DOWN AND HIT THE ROAD!!!
1940 Ford Dlx Coupe
1969 Mach1
my56chevytruck is offline   Reply With Quote
Old 06-22-2022, 08:48 AM   #156
56 3100
56 3100's Avatar
Re: 1956 3100 build
hey my 56 color is chrysler prowler orange. and staying with carb a holley.
Old 06-29-2022, 09:15 AM   #157
my56chevytruck
Re: 1956 3100 build
glad to see you're using a carb!!
1940 Ford Dlx Coupe
1969 Mach1
Old 07-02-2022, 04:04 PM   #158
56 3100
56 3100's Avatar
Re: 1956 3100 build
its a pro systems carb throttle response was pretty wicked when it was running on test stand.
Old 07-07-2022, 02:21 PM   #159
56 3100
56 3100's Avatar
Re: 1956 3100 build
Got interior pieces back today! i am happy how dash valance,and speaker kick panels turned out my fiberglass work tuned out in the end
vintage air/sanden ac compressor showed up today as well. A ebay score! polished open box cheaper than i can buy regular sanden for.
Old 07-15-2022, 07:30 PM   #160
Booxr
Re: 1956 3100 build
just back from body guys shop and we installed cab on frame today cant wait!
Just went thru your entire thread. The work you do is very impressive. Your truck looks amazing. I was wondering if you could give me some details on your rear axle setup? I see your width is 54". What is your tire width and wheel specs?
Booxr is offline   Reply With Quote
Old 07-16-2022, 09:04 AM   #161
Jason 56
Re: 1956 3100 build
Just read through your thread. Just found it! I don’t get to the main forum page very often. Love the color. You do great work. Hope you get to drive it before it gets too cold. Can’t wait to see it done.
http://67-72chevytrucks.com/vboard/s...d.php?t=780018 Jason’s 56 build
Jason 56 is offline   Reply With Quote
Old 07-16-2022, 09:31 AM   #162
56 3100
56 3100's Avatar
Re: 1956 3100 build
Hey Jason i didn't do paint part wish i could. i did all rest older brother is certified welder .he welded in camero clip and C notch. Booxr rear tires are hoosier 31x16.50 on 12"wide weld pro star rims.back spacing around 4 1/2" 4link is chris alston pro street with urethane rod ends. not seen in pics is strange engineering coilovers. 9"ford rear has 4:11 gears
Old 07-19-2022, 08:47 AM   #163
my56chevytruck
Re: 1956 3100 build
with that rearend gearing I assume (or should I) that you are using an overdrive tranny?? 700R by chance.
1940 Ford Dlx Coupe
1969 Mach1
Old 07-20-2022, 06:12 PM   #164
56 3100
56 3100's Avatar
Re: 1956 3100 build
Hey MY56 i have a turbo 400 and 4L80 cores (80 a lot more expensive t build) so will have to decide soon.
Old 07-26-2022, 09:09 AM   #165
my56chevytruck
Re: 1956 3100 build
Been looking over your build and I have a question. After repainting the cab steps, will you leave them painted or going to put something over the fresh paint??
1940 Ford Dlx Coupe
1969 Mach1
Old 07-26-2022, 09:49 PM   #166
56 3100
56 3100's Avatar
Re: 1956 3100 build
probably do as Ogre suggested and use 3M FILM Protection.
Old 07-31-2022, 07:16 PM   #167
bowt1ed
Re: 1956 3100 build
Hi Dan thanks for the encouragement.its goes without saying this site is a great source of ideas. onto the dash extension. it is 1/4" plywood for main length. the ends are glued on with PL premium. and a couple small nails. a couple hidden screws holding sides to body. mailing tube is used for curved on bottom. i just shaped regular cardboard for end corners. it is going to be mounted to bottom of dash with some old pieces of shelving channel.i went with 73-87 chev truck emergency brake pedal. as i would not have been able to put extension on drivers side with underdash pull handle .
Hey 56, I was reading back through where you used a 80 GM parking brake assembly. Where/how did you mount the release handle, with your dash extention? Any more pics?
Thanks, Jim
bowt1ed is offline   Reply With Quote
Old 08-02-2022, 09:19 AM   #168
56 3100
56 3100's Avatar
Re: 1956 3100 build
Hey Jim i used a piece of 1/8 angle steel for supporting release rod. you can see rounded edge in this pic.
Old 08-02-2022, 11:48 AM   #169
bowt1ed
Re: 1956 3100 build
Gotcha. I didn't see where it hangs just beneath dash extension in the other pic. Thanks!
Old 08-11-2022, 05:34 PM   #170
bowt1ed
Re: 1956 3100 build
Hey 56, after looking at other 73-87 GM parking brake assemblies they all look the same, but not like yours in your pic. They seem to have a longer arm and stamping. Do you know the exact year that you used?
Thanks, Jim
Old 08-14-2022, 04:53 PM   #171
56 3100
56 3100's Avatar
Re: 1956 3100 build
Hey bowt1ed i did same as OrrieG on this forum did for his brake. i went this route because of under dash valance . i put out a message on facebook to someone i knew that had some 73-87 chev/gmc squarebody parts. here is measurement of pedal length.10 1/2" from pivot point to bottom.
Old 10-27-2022, 09:44 PM   #172
56 3100
56 3100's Avatar
Re: 1956 3100 build
got 3 point seat belts fabbed up. fished 1/4" x 1 1/2" flat bar up in pillar(not seen in pics) also used same size flat bar for belt points on floor. 1/2" bolts. someone on this site suggested dodge dakota and it worked out well using rear set( less wear).
sound deadner started as well.
Old 11-05-2022, 09:23 PM   #173
56 3100
56 3100's Avatar
Re: 1956 3100 build
tried my luck on karfing wood to curve for subwoofer box/amp mounting. allowing back of cabinet to follow cab shape where amps are mounted.
cuts made here
box test fit. happy with curves in areas behind amps.
black carpet arived time to cover it soon..
Old 11-07-2022, 04:37 PM   #174
joedoh
joedoh's Avatar
Re: 1956 3100 build
really coming along! very nice work!
Old 11-18-2022, 09:00 AM   #175
56 3100
56 3100's Avatar
Re: 1956 3100 build
thanks joe .here it is with carpet on it. didnt work work out too bad for first time glueing on carpet.
