![]() Join Date: Aug 2014
What are these brake bracket lugs called and where to find them?
Hi all one of my under the dash brake brackets is missing one of the four studs and first I would like to know what they are called and second if anyone could recommend where I could buy a replacement I would really appreciate that, thank you all for all your help
![]() ![]() Join Date: Oct 2014
Re: What are these brake bracket lugs called and where to find them?
Spitballing here, but they almost look like wheel studs.
thank you, that is a pretty good S.W.A.G.
so I found this one, it doesn't say if it's coarse or fine thread, and most wheel lugulators are fine thread for that extra strength and all |
shoot according to this Quad-Logic website it's 3/8"-24 so fine thread and my OCD won't allow that since the other three are coarse
Sportsman 600 Front and Rear 3/8″ Wheel Stud and Nut |
probably the raddest US Hex Bolt Sizes and Thread Pitches chart I have ever seen
![]() Join Date: Mar 2003
If push comes to shove, just find the appropriate length bolt and weld it to the plate. It is a 3/8-16 bolt/stud. Or actually, use the other 3 to mount and then just shove the bolt through and tighten it up. When is the next time it will have to be removed? Factory used studs for assembly purposes
The Older Generation
PM me your address and I will send you one. LockDoc
20' Daredevil (Ret)
![]() Join Date: May 2003
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
Harley 1969 Chevy C-10 Long Bed, 350cid, 700R4 Last edited by LNP; 07-07-2022 at 11:41 AM. |
#13 | |
No worries glad I could help.
Harley 1969 Chevy C-10 Long Bed, 350cid, 700R4 |
#15 |
Pretty sure someone has gone in there and spot welded the remaining 3 on there that wasn’t factory.
Edit: I was wrong. I checked and mine are spot welded on too. Last edited by indymachinist; 07-07-2022 at 09:16 PM. |
#16 |
