Old 07-15-2022, 04:51 PM   #1
shambles
Junior Member
Factory Wheels
Hello,
I recently purchased a 1978 GMC C15. Pretty original basic truck. Could these be original wheels to the truck?
shambles is offline   Reply With Quote
Old 07-15-2022, 06:14 PM   #2
Keith Seymore
Keith Seymore's Avatar
Re: Factory Wheels
Yep.
Those are the optional aluminum wheels.
Do you have the SPID label for the truck?
PH7 = forged
N90 = cast
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 07-15-2022, 07:31 PM   #3
shambles
Junior Member
Re: Factory Wheels
I do have the SPID:
That's part of why I was wondering. Doesn't seem to be any wheel options.
Old 07-15-2022, 07:46 PM   #4
Keith Seymore
Re: Factory Wheels
Yeah - somebody stuck those on there.
Would have had the base steel wheels, on (as you say) a pretty base truck.
K
1979-1986
1986 - 2019
Old 07-15-2022, 07:47 PM   #5
Dead Parrot
Re: Factory Wheels
Optional wheels don't seem to fit the SPID theme of basic truck.
Pure speculation:
Dealer add after purchase.
Swap from another truck where that customer didn't want the aluminum wheels. Could be a buyer wanted a well optioned truck already on the lot except for the factory installed optional wheels.
A PO added wheels well after purchase date.
Dead Parrot is offline   Reply With Quote
Old 07-15-2022, 07:55 PM   #6
shambles
Junior Member
Re: Factory Wheels
Sort of what I thought too. The paint is the same. The SPID says solid color, but it has two tone white. I think it was dealer added the paint. Could also be previous owner.
Old 07-15-2022, 10:48 PM   #7
Corts60
Just here to tinker
Corts60's Avatar
Re: Factory Wheels
Man I really want a set of those wheels. Ive always loved them.
Old 07-16-2022, 02:06 AM   #8
HOTFUN
HOTFUN's Avatar
Re: Factory Wheels
Hard to tell from the angle but those look like the narrower version from the GM vans with the optional wheels. If I remember right they were like a 6 or 6.5" wheel where the pickups were 15x7's
'66 CST BBW swb fleet 327 fac ac
'67 CST 4x4 swb 327 factory #'s V8 stepside project
'72 Cheyenne K20 50k original
'72 CST Blazer K5 owned 30+yrs
'73 Sierra swb 4x4
'74 Cheyenne Super swb w/16k actual
'71 & 72 Cheyenne K10 4x4 swb's
'70 426 HEMICUDA conv SHAKER 4 sp Dana 60
'60 Impala conv 3rd owner
'72 GMC K2500 4x4
'59 Apache CST BBW fleetside swb 283
'73 ElCamino SS LS1 T56 true SS bucket tach
'76 ElCamino SS 52k survivor
'87 Grand National 41k True 2nd to last built in 1987.
'86 K30 454 SRW fleetside CA since new
'88 Trans Am GTA 39k bought new
2018 DEMON plum crazy @ 840HP! "Need for speed"
HOTFUN is offline   Reply With Quote
Old 07-16-2022, 09:49 AM   #9
shambles
Junior Member
Re: Factory Wheels
You could be right. They look a little narrow. Is the width stamped on the back? I would like to score a set of steelies with GMC hubcaps. Although that may be awhile. I got to get this thing running first.
Old 07-16-2022, 01:02 PM   #10
Pontiac1976
Pontiac1976's Avatar
Re: Factory Wheels
shambles:
Yes, All GM Wheel are stamped most will be close to the valve hole 5"-10". Could be on front or back, But that style rim would be on the back.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
