Old 07-06-2022, 12:32 PM   #176
Grizz1963
Grizz1963's Avatar
Re: A '62 has to get back on the road
Originally Posted by Braunschweiger View Post
Thanks for the kind words.
Today it ran again for the first time, a bit pre-primed, waved the key and hey it started, don't let it run for long, no cooler is installed yet. But he drives forward and backward, idiotlights go out, when the engine is running.
I'm very happy with myself.
BRRRRRMMMMM……. was für ein tolles ergebnis.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline   Reply With Quote
Old 07-13-2022, 02:23 PM   #177
Braunschweiger
The Watercooler is now also installed, I screwed aluminum L-profiles to the radiator support and filled up all the liquids, now the truck drives under its own power, purrs like a cat, pictures outside.
I'm completely in love with the C10.
Greetings Harald
My 62 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=829782
Braunschweiger is offline   Reply With Quote
Old 07-13-2022, 02:43 PM   #178
SCOTI
SCOTI's Avatar
Lookin good!
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-13-2022, 03:36 PM   #179
Grizz1963
Grizz1963's Avatar
Watercooler/Radiator is one of the last purchases I need to buy for my C10
Looking very good.
Old 07-19-2022, 07:16 AM   #180
Braunschweiger
Now the Hood is being worked on, it has a few rust holes in the front and a lot of dents, so I started knocking them out, fortunately they are on the side and on the edge and not on the surface, the risk of working a frog in is significantly lower 😀
Greetings Harald
My 62 build thread
Old 07-19-2022, 05:42 PM   #181
Grizz1963
Grizz1963's Avatar
The hood is a MASSIVE JOB
Good luck.
Old 07-19-2022, 07:03 PM   #182
SkinnyG
SkinnyG's Avatar
Be mindful keeping the heat down when welding patches. Stuff moves on you.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 07-20-2022, 01:08 AM   #183
Braunschweiger
Thanks for the tip, I'll step-weld the patches point by point and cool them with compressed air and take my time, that's going to be the difficult part
That's right, the hood is a monster to put on the holder alone, oh man.
Greetings Harald
My 62 build thread
Old 07-22-2022, 11:32 AM   #184
Braunschweiger
No progress on the hood and didn't get any further, the truck still wanted to have a few things done, the gearbox had a leak on the kickdown cable, resealed, the water temp always showed too hot, although the engine was only 84° /183° Fahrenheit had been checked with the infrared gun.
With a variable resistance fixed, the needle is now nicely in the middle, now the heating core has leaked, removed and taken to the cooler shop to be repaired, takes about 3 weeks, I'm glad I put the truck into operation early enough to fix the mistakes
Greetings Harald
My 62 build thread
Old 07-23-2022, 01:26 AM   #185
SOON2BLAZE
SOON2BLAZE's Avatar
that color combo looks amazing! Great work!
SOON2BLAZE is offline   Reply With Quote
Old 07-30-2022, 01:32 PM   #186
66C10LB
Great to see the progress of your build in detail. Looking forward to seeing more.
66C10LB is offline   Reply With Quote
Old 08-05-2022, 06:21 AM   #187
Braunschweiger
Well, the Hood is a huge thing. But now after removing the dents and apply metal filler, sanding, 2K epoxy could be applied, sanding, then again apply filler, sanding, phew..... and now there was a thick coat of filler primer paint.
Greetings Harald
My 62 build thread
Old 08-05-2022, 08:16 AM   #188
Joe Pass
Joe Pass's Avatar
Wow...nice work
Joe Pass is offline   Reply With Quote
Old 08-05-2022, 08:54 AM   #189
Grizz1963
Grizz1963's Avatar
And just like that……
Magic.
Great stuff. Well done, again.
Old 08-10-2022, 01:29 AM   #190
Braunschweiger
The Hood is painted with filler primer and now everything is sanded, my arms are falling off, what a huge part, what are the guys doing with the C10 panel? I'm satisfied everything is smooth and looks good, I'm excited to see how it will look after painting.
Greetings Harald
My 62 build thread
Old 08-10-2022, 08:32 AM   #191
Grizz1963
Grizz1963's Avatar
I think most guys agree, it is a huge part.
Well done.
Old 08-11-2022, 03:10 PM   #192
pdxhall
pdxhall's Avatar
The hood looks great. I'm close behind you. I'm ready for another coat of epoxy and more blocking. You're giving me incentive to continue but I've got this rear diff. thing going on.
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is offline   Reply With Quote
Old 08-12-2022, 03:29 PM   #193
Braunschweiger
Today there was a change, we went to Hamburg and picked up the Model A, after 6 months it arrived in God Old Germany from New York State and is now in our hall, it looks a little tattered, is but absolutely solid and still with the first paint, hard to believe.
Greetings Harald
My 62 build thread
Old 08-12-2022, 03:43 PM   #194
SCOTI
SCOTI's Avatar
Digging the Model-A!
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-12-2022, 03:52 PM   #195
Braunschweiger
Sweet, It looks beautiful.
I'm looking forward to doing this project as well, it should continue to run with a mildly tuned 4Banger, as a mild 40's HotRod.
Something like that:
Greetings Harald
My 62 build thread
Old 08-12-2022, 03:58 PM   #196
Grizz1963
Grizz1963's Avatar
WOW
WOW
WOW
That is lovely.
I hope you will carry on reporting on it here.
Old 08-12-2022, 04:21 PM   #197
Braunschweiger
I can do that, the C10 is still in the queue and I'm happy about the progress on it. I bought Model A spontaneously because it was in such good condition that it still has to wait.
Greetings Harald
My 62 build thread
Old 08-12-2022, 06:42 PM   #198
SCOTI
SCOTI's Avatar
We're looking for a black coupe. Going to do a hot-rod though. The 4-banger stuff is cool but I'd rather have a little more HP/TQ than they deliver (w/o breaking the bank). An updated trans w/better gearing as well....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-12-2022, 09:19 PM   #199
SkinnyG
SkinnyG's Avatar
I'm seriously considering doing a T-Bucket or some sort of rat rot using all the drivetrain I took out of my '61.
Old 08-13-2022, 03:19 AM   #200
Braunschweiger
That's right, building a 4Banger is very expensive, in the Netherlands there is a very experienced engine builder who builds many Model A engines, including the Burtz engines. Here in Germany there are strict approval regulations, it is now very difficult to approve hotrods with other drive trains, or chopped or slammed. You need a specialist who knows his stuff and does the approval so that the authorities don't shut down your car, hard times for Roder. And I'm fascinated by the 90-year-old technology.
Greetings Harald
My 62 build thread
