Is there an oil pressure gauge with 60 PSI maximum?
Hi all. I made the mistake of installing an oil pressure gauge that has a 100 psi maximum reading. This means that it always looks like I have no oil pressure. Back when I had the factory 60 psi oil pressure gauge, this wasn't a problem. The gauge would at least read that there was pressure. I'm hoping that someone makes aftermarket gauges that look nicer, but only go to 50 or 60 PSI.
I know you can buy those factory replacements, but it would look out of place as the rest of my gauges are non-factory. 87 5.7L if that helps. Thank you! |
![]() ![]() Join Date: May 2015
Re: Is there an oil pressure gauge with 60 PSI maximum?
I just googled [ 0-60 psi oil pressure gauge ]...it brought up many choices..try that and pick out what you like
You didnt state ,size/dia, color, elec sender, mechanical sender, or any other info
Nor what brand type you had.
![]() Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
Moderator
![]() Join Date: Oct 2008
GM made stock gauges with 0-60psi and 0-80psi. Both senders are 0-90Ω
My tractor has a 0-40psi gauge and I've seen 0-60psi gauges VDO V350040 is an 80psi oil pressure gauge and they make up to 150psi oil pressure gauges ( I used one on my 1982 VW Rabbit Diesel ) and as low as the VDO A2C59514210 with a 30psi sweep
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
