It's Better With Nitro
Re: Trailing Arm Crossmember Question???
It kind of depends on what you plan on doing or how you intend to drive your truck. Using the upper holes moves the instant center forward and up for better traction in racing applications since our trucks tend to have a lot of chassis weight bias to the front.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
| Bookmarks |
