Old 12-19-2021, 02:38 PM   #1
Skymortar
Broken rear shock stud
So I am swapping rear axles on my 70 and of course one shock stud snaps. What can be done to replace that stud. Of course the mount is riveted on with no way to get to it. Has anyone had to do it? Thanks
Skymortar is offline   Reply With Quote
Old 12-19-2021, 06:23 PM   #2
notsolo
notsolo's Avatar
Re: Broken rear shock stud
If it's the cup shaped piece, cut the stud close to the cup. Drill out and replace with grade 8 bolt ...sized for inside of shock, double, washers, double nut on back. Will be hard to get to...possible replace and bolt on another shock mount....maybe some one else will chime in with better option
notsolo is offline   Reply With Quote
Old 12-19-2021, 06:48 PM   #3
1rippen6
I should have another shock mount, if you decide to go that route.
1rippen6 is offline   Reply With Quote
Old 12-19-2021, 09:10 PM   #4
Skymortar
Thanks guys. I ordered one of those Monroe threaded repair studs. If I can’t get to the back of it I think I’ll grind out those big rivets and grade eight bolt the mount back on
Old 12-20-2021, 12:46 PM   #5
kwmech
there's this I've seen somewhere
Old 07-26-2022, 05:01 AM   #6
k5swy
Had that happen to me also.Had a spare tho, just ground off the rivets and bolted it back on .
k5swy is offline   Reply With Quote
