Old 07-26-2022, 11:11 AM   #1
hatzie
Moderator
hatzie's Avatar
Re: 4L80E for an LS Swap.
Originally Posted by THI View Post
I have a 1997 4L80E for my LS swap on my Chevelle, GM makes a dust cover for the earlier 4L80E's to bolt up to an LS.
You didn't run into issues with the torque converter to flex plate bolt circle?
The other gotcha I've heard is that you can't use all the bolt holes in the smallblock bellhousing when you mate it to the LS.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 07-26-2022, 11:42 AM   #2
THI
Active Member
THI's Avatar
The bolt hole near the #8 cylinder is not drilled and tapped on the block because it there is not enough room for threads there on the LS block. It makes up for it with holes drilled and tapped in the oil pan - that is why there is a specific dust cover made by GM (19259119) to fit the earlier 4L80E's to an LS block.
As for the torque converter/flexplate issue, there are aftermarket flexplates that use the 6-bolt 11.5" bolt circle
THI is offline   Reply With Quote
Old 07-26-2022, 02:36 PM   #3
A.Delaney
A.Delaney's Avatar
Was this the reason for the 99 and later?
72 Chevy C20
86 Silverado Shortbed
A.Delaney is offline   Reply With Quote
