Old 08-01-2022, 12:36 PM   #1
70cst
70cst's Avatar
Turning Issue. SOLVED!! Center-link
I have a 72 5 lug disc brake set up on my 70 C10. Way back I had ECE 2 1/2" Drop Spindles installed ... I have rubbing issues where the truck has a short turn radius ... when I turn my truck it acts like it’s a 4x4 and I get that 4x4 turning hop feeling. If I go with a 2: Drip Spindle ... in theory that should raise the front end about 1/2" which is all the clearance I need. Your thoughts … No its not the wheel hitting as I have done the grinding to make clearance. Check out the pics. Thanks
PS: I have a factory 402BB if that makes a difference...
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 08-01-2022, 12:49 PM   #2
72SB
Re: 2/1"Drop Spindle Question - Turning Issue.
IMHO using lowering coil springs vs drop spindles is the way to go
https://www.cjponyparts.com/ridetech...20Search%20Ads
72SB is offline   Reply With Quote
Old 08-01-2022, 01:02 PM   #3
70cst
70cst's Avatar
Old 08-01-2022, 01:14 PM   #4
CC69Rat
CC69Rat's Avatar
I think maybe your center link is on backwards(?) I'm not sure.. but I think it goes castle nuts out. That would definitely impact your turning radius.
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 08-01-2022, 01:28 PM   #5
70cst
70cst's Avatar
It very well could be.
This truck was redone years ago but I only started driving it a couple years ago and I am now trying to fine tune it.
Old 08-01-2022, 01:38 PM   #6
68 P.O.S.
I can't tell if the centerlink is backwards, but the tie rods are for sure
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 08-01-2022, 01:44 PM   #7
72SB
These are for SB/BB, 70-72 C10. 2" drop
https://www.summitracing.com/parts/M...engine-type/v8
https://www.summitracing.com/parts/m.../1972#overview
Old 08-01-2022, 02:06 PM   #8
70cst
70cst's Avatar
The Centerlink according to a 70 Suspension drawing sure looks to be backwards. Looks like whoever did the underneath had no clue...
Old 08-01-2022, 02:07 PM   #9
67C10Step
67C10Step's Avatar
First thought I had was, "Shouldn't the tie rods be coming in from the rear with the nuts out the front?" We recently had another member on here with turning issues that fixed up.
1967 C10
1997 Ford Ranger
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
Old 08-01-2022, 03:04 PM   #10
lolife99
67-72 parts collector,…
lolife99's Avatar
Your center link is definitely on backwards.
It needs to be removed and swapped end for end.
Inner tie rod nuts need to be on the FRONT SIDE of the centerlink.
Keith
Convert to disc brakes.
Old 08-01-2022, 03:23 PM   #11
70cst
70cst's Avatar
Re: 2 1/2 " Drop Spindle Question - Turning Issue.
Thanks All
Can someone send me a picture ... Thanks
Old 08-01-2022, 03:36 PM   #12
67C10Step
67C10Step's Avatar
I could have sworn I had photos of mine but could not find one. Here is one from the web. Driver's side but you can see how the inner tie rod comes in from the rear of the center link.
1967 C10
1997 Ford Ranger
2020 Toyota 4Runner
2024 Toyota Tundra
Old 08-01-2022, 03:58 PM   #13
Accelo
Accelo's Avatar
Yup, just went through this. They are backwards. It will drive so much better you will not believe it. Toe in will have to be adjusted. Mine was way out after I swapped the center link. You will have to turn the wheel hard over to get it installed as there isn't enough room to install the center link with the wheels straight. Per LocDoc's recommendations install 90 deg fittings to allow for greasing if they are not already installed. Remember "NUTS FORWARD" is how it's installed.
Cheers.
Accelo is offline   Reply With Quote
Old 08-01-2022, 04:14 PM   #14
70cst
70cst's Avatar
Folks ... this is a GREAT help. Thanks
Old 08-01-2022, 07:42 PM   #15
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
DeWayne, I agree with everyone else here. Swap the center link WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 08-01-2022, 10:04 PM   #16
70cst
70cst's Avatar
Do you all think the the tie rods are also backwards?
Old 08-01-2022, 10:23 PM   #17
lolife99
lolife99's Avatar
You will need to loosen the tie rod sleeve bolts to rotate them 180 degrees.
But most likely you will need to adjust the toe. Get the wheels as straight as possible and then take it to get the front end re-aligned.
Keith
Old 08-01-2022, 11:09 PM   #18
70cst
70cst's Avatar
Again folks ... you all have been a great help. I take the Circuit Rider in this Friday and all the work needed will be done and I look forward to being able to making turns.
Old 08-02-2022, 09:45 AM   #19
Accelo
Accelo's Avatar
FYIO, I had my truck aligned twice and the alignment guy didn't catch it issue. They even drove the truck before and after. So I have three $90 alignments! It was my bad though. I knew it was possible and my research was inadequate. You will like your truck a lot more after it's back to factory.
cheers.
Old 08-03-2022, 01:56 PM   #20
70cst
70cst's Avatar
cheers.
Yep ... its been an issue for sometime but I could never figure it out ... should have come here ffirst
Old 08-10-2022, 08:34 AM   #21
70cst
70cst's Avatar
I just got a call from the shop that does my work on the C10 ...they changed out the Center-link as it was installled backwards and they said - WOW. It is like driving a new truck. They also said the inside wheel clearance is vastly improved. I hope to pick it up today. Can't wait to drive it.
Again a great big thank you for steering me in the right direction.
Old 08-10-2022, 07:14 PM   #22
Re: Turning Issue. SOLVED!! Center-link
Good to hear. Cruise on brutha!
Old 03-04-2026, 12:11 PM   #23
StMartin55
thanks for the reply. I'll check this out
StMartin55 is offline   Reply With Quote
