Old 08-04-2022, 03:51 PM   #1
Tmeisky
Roof Rack '72 Suburban
I am looking to install an OEM roof rack on my '72 Suburban and was wondering if they are specific to the Suburban or were they the same ones offered for that era of GM station wagon as well? Any help and direction is appreciated. Thank you in advance.
Tmeisky is offline   Reply With Quote
Old 08-04-2022, 04:48 PM   #2
HO455
HO455's Avatar
Re: Roof Rack '72 Suburban
Here are some threads.
I believe they were dealership installed for the most part. With station wagon ones being narrower. But they can be found on Burbans through the 80's.
Good luck and welcome aboard.
https://www.67-72chevytrucks.com/vbo....php?p=8531779
http://67-72chevytrucks.com/vboard/s...d.php?t=531422
https://67-72chevytrucks.com/vboard/...d.php?t=741825
http://67-72chevytrucks.com/vboard/s...d.php?t=626091
There are other threads here if you type roof rack in the search box and click the 67-72 button
RIP Bob Parks.
HO455 is online now   Reply With Quote
Old 08-04-2022, 06:52 PM   #3
pontiacvince
pontiacvince's Avatar
Glad mine came with one. I saw another on a similar Suburban that had been sitting for years. It's gone now though. Green is mine.
pontiacvince is offline   Reply With Quote
Old 08-04-2022, 06:58 PM   #4
Tmeisky
Is it safe to assume that the ones that came on 73 through late 80s suburbans should fit the ‘72? It’s just drilling into the roof correct? Thanks for all information.
Old 08-06-2022, 03:20 PM   #5
pontiacvince
Mine is drilled and uses screws and nuts on the inside. I replaced the rubber under the rack and used some clear silicone to seal it.
If I were to do it again, I would use insert nuts. Much better seal and clamping and no need to have someone screwing outside and someone inside holding the nut.
Old 08-06-2022, 10:47 PM   #6
BAD1916
This is a bit off topic of the roof rack in this thread since it’s about the factory roof racks but does anyone know if any full length roof racks for the suburban that are available? I’ve looked and I haven’t found any. I have seen a few that look custom made but I wonder if a full-size van would be close enough to work?
BAD1916 is offline   Reply With Quote
Old 08-07-2022, 02:37 PM   #7
CG
BlahBlahBlah
Seeing if I can post a burb roof rack string I did a search on, crossing fingers .... It worked! Maybe you guys can find something in here ?
https://67-72chevytrucks.com/vboard/...archid=7120654
And a heads up ... some of those threads are really old so if you reply to them you might not get an answer. But there is a lot of good info scattered through them.
I did another search using the Google search button at the top of the page highlighting the 67-72 button ...
https://www.google.com/search?q=%22r...h=723&dpr=1.25
Old 08-07-2022, 06:02 PM   #8
BAD1916
Thanks for the links. I will dig into them.
Old 08-07-2022, 08:46 PM   #9
CG
BlahBlahBlah
I spent a long time browsing through them today. I really like the kind of home made ones. I'm pretty sure I have a stock one in a tube somewhere. If I remember correctly I paid way too much for it years ago. It wasn't in the shape I was hoping and I think pieces were missing.
Edit: Even if I found it I wouldn't sell it. (just in case someone thought I was trolling a sale haha)
