Old 07-29-2022, 01:42 AM   #201
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: 2wd swap
Well then, I suppose this mocked up.
KQQL IT is online now   Reply With Quote
Old 07-29-2022, 07:55 AM   #202
SCOTI
SCOTI's Avatar
Re: 2wd swap
Looks good.
Nice & level lowers. Uppers appear right on the Camber curve.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-29-2022, 12:54 PM   #203
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: 2wd swap
2° camber change thru the 7" of travel.
Old 08-06-2022, 12:49 AM   #204
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: 2wd swap
Welded out the drivers side
Old 08-06-2022, 02:09 PM   #205
SCOTI
SCOTI's Avatar
Re: 2wd swap
Looking real good!
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-07-2022, 09:28 PM   #206
Willowrun
Willowrun's Avatar
Re: 2wd swap
Yeah, nice work. Great to see your son so involved in the project.
Old 08-08-2022, 02:43 AM   #207
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: 2wd swap
Thanks, been awesome to watch him learn and understand the dynamics of the steering geometry and suspension geometry.
Old 08-09-2022, 11:43 AM   #208
SCOTI
SCOTI's Avatar
Re: 2wd swap
His teacher deserves an 'atta-boy'.
I only wish I had someone share this sort of knowledge & encouragement to soak up as much skills as possible when I was younger. He will reap the rewards now & even more as he grows.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-09-2022, 09:01 PM   #209
KQQL IT
At the body shop.
KQQL IT's Avatar
Wink Re: 2wd swap
Thank you.
But at this point I'm just the enabler.
The depth of his understanding is way beyond my knowledge.
He was explaining to me how he may put the upper ball joint on the bottom of the upper arm to help the roll steer.
So neat to see it all making sense to him.
•Edit•
Maybe posted this before.
2010 beginning of our dash swap.
Never knew he was paying that much attention
Old 08-27-2022, 09:17 PM   #210
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: 2wd swap
Today we swapped center sections.
3.82 to a 2.91
Forgot how nice the ring & pinion set was in the 3.82
Old 09-01-2022, 10:13 PM   #211
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: 2wd swap
Well then.
J decided the rake was drastic
Old 09-19-2022, 11:14 AM   #212
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: 2wd swap
The cast iron hub we made had some serious run out issues. Don't know if it was the studs we pressed in or the chineseum rotors.
My kid found these wilwood hubs for a c10 spindle.
Wilwood 270-13217 Hub
They'll work with our rotor and caliper with about 1/8 machined off the caliper bracket and machined another 1/8 off the od to fit the Id of our rotors.
Now onto motor mount and transmission mount.
Fusion360 and sendcutsend are cutting those for us
Old 09-20-2022, 10:34 PM   #213
Willowrun
Willowrun's Avatar
Re: 2wd swap
Still following. Cool stuff.
Old 09-22-2022, 07:59 PM   #214
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: 2wd swap
In the sun.
Some fall cleaning since it's cool enough to do something other than sweat.
His 1st design motor mount, I wanted to use oem style clamshell stuff and he said it uses up to much room for headers.
Then the ratchet strap didn't get a full wrap and dropped our mockup block on our F body pan.
He handled it like a pro- owned the mistake and thankful he didn't catch it.
Old 10-05-2022, 06:08 PM   #215
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: 2wd swap
3 pass lower link. Sure why not
Old 10-12-2022, 12:58 PM   #216
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: 2wd swap
Wilwood hubs with a new caliper bracket. New shorter bolts coming.
Funny how a .250 to long of a bolt turns into a $65 order
Old 10-12-2022, 05:28 PM   #217
SCOTI
SCOTI's Avatar
Re: 2wd swap
Have your own design bracket cut?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-12-2022, 06:13 PM   #218
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: 2wd swap
Yes.
Send cut send, they have been absolutely rocking it. But we asked for powder coat and then it took them longer than usual.
My son's cad work is on point lately.
His latest project, 8-1 strictly for the sound...
Old 10-12-2022, 06:34 PM   #219
SCOTI
SCOTI's Avatar
Re: 2wd swap
Nice.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-15-2022, 02:12 PM   #220
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: 2wd swap
Afco shocks on sale ? Sure Jay
Old 10-22-2022, 12:58 PM   #221
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: 2wd swap
Take off clip to replace the aftermarket junk we had.
Is every 81-87 hood cracked in the front center?
Third hood we've ran across like that.
Old 10-22-2022, 03:12 PM   #222
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: 2wd swap
So.
Old 11-13-2022, 09:46 PM   #223
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: 2wd swap
Motors in its home.
Not sure the set back will work.
Steering box brace seems stout enough
Old 11-13-2022, 10:29 PM   #224
SCOTI
SCOTI's Avatar
Re: 2wd swap
Those pics aren't telling as far as set-back isdues.
What are you seeing?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-13-2022, 10:45 PM   #225
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: 2wd swap
The balancer is going to end up behind the center link.
