Old 08-03-2022, 04:23 AM   #1
Dogboy20
Radio/stereo connector
Was wondering if anyone had a connector that looks like this one with the same wires and everything. My 1977 c10 has the yellow wire snipped to close to the connecter to resolder it back together. if someone can give me a link to a company selling the connector with the wires.
Dogboy20 is offline   Reply With Quote
Old 08-03-2022, 10:18 AM   #2
Bandit130
Bandit130's Avatar
Re: Radio/stereo connector
Try this
https://www.carxtc.com/DELCO-GM-GM27...s_p_53568.html
1974 Cheyenne 10 LWB Stock 350 W/HEI /TH350/AC/4 BBL Quadrajet
Mopar by Birth
Chevy by Choice
Bandit130 is offline   Reply With Quote
Old 08-06-2022, 09:31 PM   #3
Pontiac1976
Pontiac1976's Avatar
If you go to the pick and pull yard you can get that Speaker wire Connector plug off any GM factory stereo car73-88 or truck73-90, from radio shop still open or try Standard auto motive wiring still may have them throw other seller. like other Summit Racing.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 08-07-2022, 02:10 PM   #4
cwcarpenter98
cwcarpenter98's Avatar
Does this look like your connector? https://www.rockauto.com/en/catalog/...connector,2612
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 350, Saginaw 4 speed
Old 08-07-2022, 10:55 PM   #5
kglowacky
check to see if you can just replace the metal connector that the wire is crimped to. Some of these plugs can be disassembled with a small small flat head
kglowacky is offline   Reply With Quote
