#176 |
![]() Join Date: Apr 2013
Re: 1971-1972 New Battery Cables
Happy anniversary Roger! Your first post on these cables was 6 years ago today. Great part for any restoration or daily driver. Can you order them for another application, or gets poss. Cable in all Red? Spring ring type. Did see your 67-70 post as well.
#177 |
Big Block
Thanks Roger. Payment sent.
#178 |
![]() Join Date: Nov 2012
I have access to battery cables for most GM cars and truck from 1960's thru the 1980's
Roger Koop |
#179 |
Can I ask you if you can get a set of cables for my 68 442, or should I pm you? Might be breaking a rule asking about a car! Let me know
Thanks |
#180 | |
Roger Koop |
#181 |
Roger Koop |
#182 |
Big Block
Thanks Roger.
#183 |
I just received another 10 Pair in on Sept 7
Roger Koop |
#184 |
I'll be ordering a set at some point in time. I have a question, however. To where does the secondary wire off the positive cable attach? Is this a ground wire? And is it necessary?
I've seen many positive cables (most negative cables have it) that don't have this secondary wire, so kind of curious. |
#185 | |
The negative cable secondary wire goes to the the fender and is for a ground.
Roger Koop |
#186 |
The small negative cable grounds the core support. It uses the same bolt on the core support as the headlight ground. The fender has its own ground that goes from the inner fender to the frame.
72 C10 lwb fleetside -stock 350/350 combo |
#187 |
Roger,
Got any 72 K20 cables ?? |
#188 |
![]() Join Date: Nov 2017
Rodger do you have anymore cables? I need a set for a 71 2wd with a 402.
#189 |
Yes I have a set.
A set of battery cables sell for $135.00 shipped. I accept Checks and PayPal.
Roger Koop |
#190 | |
Roger Koop |
#191 |
I can do Paypal, send me your paypal information I will take a set.
#192 |
![]() ![]() Join Date: Feb 2009
Hi Roger, do you have a set for a 1971 2WD 402 with A/C? For what worth I plan to mount the negative terminal per this illustration. Thank you.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
#193 |
Payment sent for my set.
#194 |
I need a set for 72, 350 4wd AC.
Thanks.
MY Facebook ( saad_alhajri ) on Instagram
#195 |
![]() Join Date: Sep 2013
This one popped back up with perfect timing. I need a set for a 1971 C-10 with 402, AC, 2WD.
#196 |
Payment sent, thanks again Roger. My truck will have 2 of the otherwise unobtainable specialty items that you supply when it is completed (bucket seat brackets and now the old-style battery cables).
#197 |
![]() Join Date: Jun 2007
I would like a set for a 1972 4X4 Blazer with AC,
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
#198 |
![]() Join Date: Aug 2018
Looking for a set of cables for my 402 BB 4x4 build. Let me know price shipped to 17532. Thank you
Posted via Mobile Device |
#199 | |
Roger Koop |
#200 |
![]() Join Date: Jul 2001
Roger, also need cables for 72 402 BB 4x4, and want the GM wire loom kit for BB. Thanks Gary
71 C-10 SWB 1969 C-30 Custom Camper Motorhome Restoration in progress. 2020 Chevy 2500 Crew 4x4 LTZ Diesel 2024 Chevy Tahoe Z71 4X4 2015 Diamond C 22' HD car hauler Bowie, Texas 76230 |
