Old 06-25-2022, 07:39 PM   #176
BIGglaSS
BIGglaSS's Avatar
Re: The Vandal. 1957 "Big glass" 3100 restomod.
My museum of good intentions: 1957 3100 BBW restomod -- 1970 442 W30
BIGglaSS is offline   Reply With Quote
Old 06-25-2022, 10:24 PM   #177
Kevin_C
truck looks amazing
1955 chevy longbed shortened, C4 vette suspension front and rear with flatout kit. Gen V LT1/8L90
http://67-72chevytrucks.com/vboard/s...d.php?t=746958
Kevin_C is offline   Reply With Quote
Old 06-25-2022, 11:22 PM   #178
oldman3
oldman3's Avatar
Beautiful truck...Jim
oldman3 is offline   Reply With Quote
Old 06-26-2022, 08:53 AM   #179
Rickysnickers
Rickysnickers's Avatar
WOW!!! NICE!! Looks like that's the north end of Eagle Rd/Willow Creek.
Old 06-26-2022, 10:33 AM   #180
BIGglaSS
BIGglaSS's Avatar
Yep! Took it to its first show yesterday. Next event will be Eagle fun days on July9.
Thanks for all the comments! Still working out lots of little issues, but at least it's usable.
It has a cooling issue, that doesn't make sense. I have a 2 speed fan wired with relays per the instructions on lt1swap.com. It works great, until it doesn't... The low fan logic has blown out 2 relays and one fuse. I have tested the logic multiple times by grounding the leads to fan1 and fan2, like the computer does. When cruising with good airflow, the water temp (reading from the ECM) cycles between 200-210. Somewhere in that range, the computer turns on the low fan. I have no idea what temperature the computer turns on the high fan, or if it is even programmed to do so. Anyway, once the relay "blows", it starts cycling like a turn signal, and the water temp runs up to 225+ and I shut 'er down.
Long story, after getting home and sitting all evening, there's a big puddle of coolant on the garage floor. I haven't investigated yet. It looks unrelated to the fan issue. Possibly a heater hose or the coolant overflow can.
Old 06-26-2022, 04:45 PM   #181
BIGglaSS
BIGglaSS's Avatar
The coolant leak turned out to be a heater hose clamp that never got tightened.
Swapped in another relay, different brand this time. Going for another test run.
Old 06-27-2022, 08:28 AM   #182
youngrodder
youngrodder's Avatar
Very, very nice. Way to go. Love it.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is online now   Reply With Quote
Old 06-27-2022, 12:36 PM   #183
BIGglaSS
BIGglaSS's Avatar
Thanks!
I think the cooling problem is computer related. Somewhere in the 210 temp range it cant make up it's mind to run fan LO or fan HI. The cycling causes the relays to overheat. When I pull out the relay, it is SO HOT that I can't touch the prongs. Looks like I'm going to have to find a local tuner to take a look at it.
Problem 2 could be a stuck thermostat. Since this engine had been sitting for 13 years, I put in a new 187 thermostat before getting it running. The new thermostat housing leaked on the first fill, so I glued it on with "The Right Stuff". I wonder if some got into the thermostat and glued it shut. When the engine temp is showing 210, the infrared thermometer shows the top of the radiator to be 200 degrees, and the bottom is only 130.
Anyway, it's going to be a while before I can troubleshoot it.
Old 06-27-2022, 01:04 PM   #184
NorCalGal
NorCalGal's Avatar
Well done, that is a beautiful truck.
Jan's 53
NorCalGal is offline   Reply With Quote
Old 06-27-2022, 06:48 PM   #185
joedoh
joedoh's Avatar
this is one of the best trucks on the website! beautiful job!
Old 06-29-2022, 11:56 AM   #186
OKGMC4
OKGMC4's Avatar
Looks great!!!
56 GMC BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=368649
69 long bed Chevy turned 67 gmc jimmy roadster:
https://67-72chevytrucks.com/vboard/...d.php?t=851167
OKGMC4 is offline   Reply With Quote
Old 07-04-2022, 03:28 AM   #187
Nut Case
Nut Case's Avatar
BG
This TK is sweet, grand job. keep on keepin on
Strong Work
nutz
Been there, wrecked that
Nut Case is offline   Reply With Quote
Old 07-06-2022, 11:40 PM   #188
mr.mud1
mr.mud1's Avatar
that sir,is one gorgeous truck.the metal work is top quality,a real beauty.
mr.mud1 is offline   Reply With Quote
Old 07-08-2022, 01:19 PM   #189
bosco
bosco's Avatar
She has turned out beautiful. Very cool ride. Enjoy.
bosco is offline   Reply With Quote
Old 07-10-2022, 09:49 AM   #190
Rickysnickers
Hey, I saw your truck at the Eagle Fun Days. It looks even nicer in person!
Old 07-10-2022, 10:42 AM   #191
BIGglaSS
BIGglaSS's Avatar
Thanks to everyone for the positive comments, it keeps me going!
Thanks! I couldn't believe how much attention the truck got! When I was at the truck, lots of people stopped to talk about it. I was bummed that the parking dude made me park in the dirty lot back 40. Seriously, he told me to get a rag and quit crying!! Either way, I still had a good time, enjoyed "talking shop" with others. Now I'm motivated to work on more finishing touches.
And, when I got home, my new bumpers were waiting in the driveway!
Old 08-13-2022, 11:45 PM   #192
BIGglaSS
BIGglaSS's Avatar
Old 08-14-2022, 09:51 AM   #193
Jason 56
Truck looks amazing. Drive and enjoy the fruits of your labor!
http://67-72chevytrucks.com/vboard/s...d.php?t=780018 Jason’s 56 build
Jason 56 is offline   Reply With Quote
Old 08-15-2022, 11:20 AM   #194
Kevin_C
Looks really sharp. well done
Old 08-16-2022, 09:24 AM   #195
youngrodder
Great pics. Looks good out in the wild.
Marc
Old 08-16-2022, 12:44 PM   #196
joedoh
joedoh's Avatar
gorgeous man!
Old 08-17-2022, 09:42 AM   #197
oldman3
oldman3's Avatar
Great truck...Jim
Old 08-17-2022, 09:29 PM   #198
vintovka
vintovka's Avatar
Looks great. Be thankful you're done. Given todays circumstances and inflation many would not start a project like yours. Again Beautiful truck and congrats!!!
vintovka is offline   Reply With Quote
Old 08-24-2022, 10:32 PM   #199
G&R's57GMC
G&R's57GMC's Avatar
The LS engines run at 210* normally. Your radiator is doing its job cooling .
Now as for the fan cycling you can adjust the on and off temperature for both fans with a tuner via the under dash diagnostic port .
If the relays are getting to hot it could mean the fans are pulling too much amps.
Glen & Jane's Rides
‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008
7 other cars & trucks , 5 trailers
'56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020
’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020
My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275
G&R's57GMC is offline   Reply With Quote
Old 08-25-2022, 12:15 AM   #200
dsraven
Check out the pirate 4x4 site for bella vista's write up on the ls cooling system and how it works. You cant think like the old school systems with an ls engine.
I would do an amp draw test on the motors if the relays are getting hot.
dsraven is online now   Reply With Quote
