Old 06-15-2018, 10:51 AM   #26
RogerKoop
RogerKoop's Avatar
Re: 1967-1970 New Battery Cables
Originally Posted by Njeiv View Post
Hi Roger, do you have a set for a 68 with the auxiliary battery option?
Yes id do haves sets. PM sent
Roger Koop
RogerKoop is offline   Reply With Quote
Old 06-15-2018, 12:03 PM   #27
Njeiv
“On The Hunt”
Njeiv's Avatar
I’ll take a set-up for dual battery, big block with A/C
Njeiv is offline   Reply With Quote
Old 06-15-2018, 05:11 PM   #28
StruttinSoul
Do you have a set for my 1968 Chevy K10 (w/327)? Also - what's the main difference if it has AC? I will be adding aftermarket AC eventually.
StruttinSoul is offline   Reply With Quote
Old 06-15-2018, 07:29 PM   #29
RogerKoop
RogerKoop's Avatar
I have the pos cable and one neg cable with out a bag so I don't know if it will fit. Its 21" from eyelet to eyelet. Check and see if it will would work on your truck. If it does I have a pair. Let me know.
Roger Koop
Old 06-16-2018, 07:08 PM   #30
StruttinSoul
Hmm the negative cable on the truck right now is 28 inches long and I think factory for it was 25
Old 06-17-2018, 05:04 PM   #31
RogerKoop
RogerKoop's Avatar
I'll need to have one made. Should take a couple of weeks. Will that work for you?.
Roger Koop
Old 06-17-2018, 05:42 PM   #32
RogerKoop
RogerKoop's Avatar
I checked the GM parts book and it should be 32" long.
Roger Koop
Old 06-19-2018, 11:43 PM   #33
StruttinSoul
Hey! That works for me
Old 09-12-2019, 05:34 PM   #34
RogerKoop
RogerKoop's Avatar
I just received more battery cables if anyone is interested.
Roger Koop
Old 10-03-2019, 06:05 PM   #35
frankinstein
I would like a set 67 K10 327 with AC. I sent a PM also
frankinstein is offline   Reply With Quote
Old 08-14-2022, 05:29 PM   #36
RogerKoop
RogerKoop's Avatar
It looks like I missed your PM. Sorry about that. I do have a pair of cables.
Thanks Roger Koop
Roger Koop
Old 08-14-2022, 05:53 PM   #37
IronCanine
IronCanine's Avatar
Roger...I'll take a set if you've got em. 1970 350 4WD A/C
Thanks.
IronCanine is offline   Reply With Quote
Old 08-14-2022, 08:21 PM   #38
RogerKoop
RogerKoop's Avatar
Thanks.
Yes I have a set of spring type cables.
Roger Koop
Old 08-14-2022, 08:48 PM   #39
IronCanine
IronCanine's Avatar
PayPal sent. Thanks Roger.
Old 10-20-2023, 08:08 PM   #40
DL's 68
Hi Roger,
I need a set for my 1968 C20 327 w/factory AC. Looks like the cables I have are original. Not exactly sure where the measurements are made from but the negative is around 26" and the positive is about 54". Both are black, top post.
Would you have a set for that application?
Thanks a bunch,
Dave
DL's 68 is offline   Reply With Quote
Old 11-01-2023, 12:33 PM   #41
RogerKoop
RogerKoop's Avatar
Originally Posted by DL's 68 View Post
Hi Roger,
Thanks a bunch,
Dave
I have pair that the positive that is 59" and a negative that is 29" long. Will that work for you?
Roger Koop
Old 11-12-2023, 06:49 PM   #42
DL's 68
Thanks for getting back to me, Roger. I think that the ground will work but the positive might be a bit too long. It sounds like you have access to GM part numbers. I found a number on the positive cable today. It is stamped as 1235. Does this number cross to anything in the parts reference? The ground has no number - which makes me think that the original could have been replaced at some point with a slightly shorter cable.
Old 12-03-2023, 06:33 PM   #43
RogerKoop
RogerKoop's Avatar
Can't find any cable with 1235.
Roger Koop
Old 01-01-2026, 01:09 AM   #44
Canuckvetter
How did I get this OLD!
Canuckvetter's Avatar
Inquiry. I have a 67, 327, dealer installed A/C. Would the cables be different with factory A/C? Shipped to Canada T0B 4J0. They may be able to ship to a US address but I will have to confirm.
1967 Oshawa built LWB Fleetside. 327,3 OTT, 515 Vermilion, CST, PS, PB, Shoulder Harness, Mechanical Diesel Tach, Vac, Kilometre Speedometer, Speed Warning, Choke Delete, Manual Throttle, Fawn interior. Dealer installed A/C 04/2015, N34 Rosewood Steering Wheel 06/2023
Members who I have met personally. Metaldoc, chevnkevin, 62 Longbed, 72LHorn, 72MARIO, YBNORML, TBONE1964, Classic Bowties, Chevemall, Dagnabbitt, Chewychevy67.
Canuckvetter is offline   Reply With Quote
