Old 08-16-2022, 09:11 PM   #1
jdaniel
brake booster swap
I am building a frakenstein truck. I mounted a 71 cab to a 03 frame, I have a 01 4 x 4 that i am parting out. I put the 01 stepside bed on the 03 frame. M y question is can i swap the 01 brake booster on to the 71 cab? I want to hook up the ABS and the 01 master wont mate up to the 71 booster, i would appreciate a little help, thanks.
jdaniel is offline   Reply With Quote
Old 08-17-2022, 05:21 PM   #2
SCOTI
SCOTI's Avatar
Re: brake booster swap
You'd need to check the mounting pattern between the older/newer boosters to determine if it can be done w/o much fuss or if it will take fabrication effort.
The new vs the old might also require a different pedal ratio so you'd need to research what the specs are for each & start from there.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 08-18-2022, 11:40 AM   #3
jdaniel
Thanks, iwas looking at the bolt pattern, but i noticed it will be very close to my shift arm also. I didnt think about pedal ratio. T he bolt pattern for the master is the same, but the recess for the masters are different, the 01 is 5/16 " bigger than the 71. I am leaning towards having it turned down, it would resolve most issues.
Old 08-18-2022, 01:52 PM   #4
SunSoaked
SunSoaked's Avatar
Hydroboost. It's worth the effort.
SunSoaked is offline   Reply With Quote
Old 08-18-2022, 03:05 PM   #5
SCOTI
SCOTI's Avatar
It's all relevant to the application. Hydroboost is great for some (many?) apps.... Not so much on others.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-18-2022, 05:46 PM   #6
KQQL IT
At the body shop.
KQQL IT's Avatar
My brother's hydro boost has proven to be a pita
Manual or vaccum for me thanks
Old 08-22-2022, 08:02 PM   #7
jdaniel
a friend of min e suggested that
